It is currently Apr Wed 25, 2018 1:46 pm
 Post subject: Philco 37-690
PostPosted: May Thu 26, 2011 7:27 pm
I bought this locally from a fellow collector last year for what I thought was a very fair price for an original finish and already recapped top of the line in 1937 Philco.
The 690 has 3 real speakers, 4 "clarifiers" and 20 tubes on 2 chassis. It was Philco's 1st major radio made to compete with some of the Scotts and other High end sets on the market. It even has a High Fidelity decal prominently displayed on the cabinet. I believe about 2500 of these were sold for a princely amount of $375.
My new baby needed a good cleaning and that was about it when it was delivered last September (photos before cleaning seen here):
I got out my cleaner and spent a day going over it and listened to it playing. All the controls worked nicely and the tweeters were more noticeable than on my 38-690 which to me is one of the best sounding radios I have heard play. I think the 37 has less Timbre but more of a natural tone sound with more emphasis on the mid range and upper frequencies.
I discovered the veneers used were spectacular and very high quality. The set cleaned up very nicely.
After a few days, I accidentally pulled the volume control shaft out while trying to remove the pressed on knob.
I pushed the set into the back room and let it sit for 8 months till last week. I got a burst of energy and decided to work on the chassis.
It turned out to be a simple repair on the volume control shaft with a small set screw tightening required.
Some photos of the beautiful factory veneers used after my simple cleaning:
The underside of the chassis-note the long copper colored shaft to the right of center. That is the volume control shaft I had to repin. Recapped in the past by an unknown person in Iowa:
A closeup of the volume shaft and the set screw that I had to tighten after reinserting the shaft:
I got out my tube tester and found I had a bad output tube (6B4) and luckily I had a good one in my tube stash. I also replaced both rectifiers with NIB tubes and now the set is really thumping. The two bass/treble(selectivity) controls both affect the sound and you can really fine tune this to your ears. The dial has a fast and fine tune control and when the bearings are good (like mine were),the tuner is a delight to dial in a station. No eye tubes here either in the 20 tube count.
I have been checking the two transformers with my new laser temp checker from Harbor Freight and after 7 hours today, I get about 108 and 97 degrees respectively. Philco used that odd setup with the rectifiers stuck on top of their transformers.
All in all a very nice radio from 1937 that showed what Philco could do if they wanted to make a nice big dog.
Thanks for looking !
PostPosted: May Thu 26, 2011 7:38 pm
VERY NICE! Makes me want to pull out my 201x and start ripping into it! I LOVE the 30's Philcos.
Joe
PostPosted: May Thu 26, 2011 9:13 pm
That's one great looking and performing radio. Philco definitely pulled out all the stops on their top end radios in 1936-1938. My 38-690 is easily the best sounding radio in my collection, and you're right -- those radios are a joy to tune. I love the look of the 37-690, though the doors aren't very practical unless you leave enough room on the sides to open and close them. Of course if you were living in a 30 room mansion that probably wasn't a huge concern. :lol:
Bob
PostPosted: May Thu 26, 2011 9:22 pm
Very Nice Bruce ...
PostPosted: May Thu 26, 2011 10:15 pm
Yessir, she's a beaut! :)
"If you write as good as you talk, nobody reads you." -- Lou Reed to a journalist, 1978
PostPosted: May Sat 28, 2011 2:43 pm
That is a beautiful radio Bruce! And, with 20 tubes it has the performance to match. A very nice find indeed!
Ed
****The only difference between a man and a boy is the price of his toy****
PostPosted: May Sat 28, 2011 2:56 pm
Nice work. Makes me want to get off my lazy butt and start working on my 37-690.
Kevin
"There Is Nothing Finer Than A Stromberg-Carlson"
PostPosted: May Sun 29, 2011 1:50 am
Bruce, what a nice looking set, love the wood, and a great job on it. I will continue working on my speaker, someone will have the proper set up. Both work well, just need to get the rest to work as a unit.
Jerry
PostPosted: May Sun 29, 2011 2:42 am
I have one, it's the highest tube count radio in my collection. Unfortunately I haven't done anything to restore it. If I don't get to it in another few years, I should probably move it along to someone who would enjoy it, but getting rid of something so heavy and valuable (?) is somewhat daunting.
Peter
PostPosted: May Sun 29, 2011 3:21 am
Very nice Bruce!
Congrats!!
Joe
 Post subject: Re: Philco 37-690
PostPosted: May Sun 29, 2011 7:13 am
The same thing happened to my 38-116 when I moved.
y2k Bruce wrote:
A closeup of the volume shaft and the set screw that I had to tighten after reinserting the shaft.
Hmm, my 38-116 didn't have a set screw, I wonder if it was removed before I got it? I think it had a clip near the front of the chassis that I lost, but now I wonder.
I havent taken the temp of the transformers of my 38-116 but after 16 hours of playing the other day it did not feel hot at all to my hand.
I am still amazed at how good my 38-116 sound but I still need to do an alignment and some cabinet work to it. I would love to have a 37 or 38-690 though. Even though I use an AM transmitter I wish one of Philco "Big Dogs" had a phone input I would love to see how it sounds with a CD player hooked directly too it.
You have a beautiful radio Bruce One other Philco I would love to have would be the 16B cathedral. It should be a little less expensive that and 37-116 and hopefully I can find one in my price range some day.
Rpd.
Radio 1240, After the Fallout...Radio Free Chillicothe
PostPosted: May Sun 29, 2011 4:10 pm
Rpd.
Bruce's radio someone had replaced the volume control or else LOST the rear clip and pin. Most likely replaced the volume control is why it had the NON-Philco shaft coupler in the radio that the setscrew came loose from. Normal is a pin in the rear end of that long shaft and a hole in the original slotted Philco volume control with a small spring steel U shaped clip. Then at the front of the chassis on the inside is a U shaped clip that slides over a slot in the shaft to keep it in place. All those were missing from Bruce's radio and the front clip must be missing from your 38-116. That front clip is a common part to lots of 37 and 38 year Philco chassis.
John k9uwa
PS: I also have a 37-690 and it is one of the best players in our collection. Probably #3 to the Z1000 Strat and the 30 tube Scott Phillly.
PostPosted: May Mon 30, 2011 1:24 am
Great Looking philco must say !
http://s693.photobucket.com/albums/vv293/dahilderbrand/
PostPosted: Jun Wed 01, 2011 3:49 am
just in case you might want to see what a philco volume control like most used back then , I posted a picture in Philco photo album
PostPosted: Jun Fri 03, 2011 8:41 pm
Bruce, I'm pretty sure that 37-690 was a Dave Johnson restoration.
PostPosted: Jun Fri 03, 2011 9:04 pm
That is a great looking radio! Philco made some great radios in the 1930's.
Post New Topic Post Reply  [ 16 posts ]  Moderator: sofaslug
Users browsing this forum: Tlc and 23 guests
