It is currently May Sun 19, 2013 7:09 pm
 Post subject: BAYGEN MODEL FPR2S-GSW WINDUP RADIO
PostPosted: Apr Mon 30, 2012 12:49 pm
Received this set at yard sale. It works well but could use an alignment because stations do not fall correctly on the dial.
Can anyone supply or suggest obtaining a schematic? It has a solar collector that can charge and power the radio simultaneously.
I have yet to test the solar function. This 5 LB solid state Gem features bands AM, FM, SW1 and SW2 to 18Mhz. cheers, john85
 Post subject: Re: BAYGEN MODEL FPR2S-GSW WINDUP RADIO
PostPosted: Apr Mon 30, 2012 2:49 pm
Good luck finding such info on a recent solid state radio. Make sure it's not a mechanical problem with the dial before you start fiddling with the adjustments. If it is previously unmolested and not a mechanical problem - there would likely be a failed or failing component causing the problem - and that would have to be addressed for a permanent cure. If it is an alignment issue - you can find some general hints here:
http://www.vintage-radio.com/repair-restore-information/transistor_alignment.html
Be mindful of the spring - uncontrolled release could injure you and/or ruin the radio.
Those, I believe, were also known under the name "Freeplay" and, at one time, had some association with Coleman (the lantern people) in the US. Maybe you could get some info from Coleman. I have one that is AM/FM - yours was intended for the isolated regions of the world (ie., Africa) - though some of the SW versions made it to the US market. I remember seeing a few of that model at the discounter "Tuesday Morning" many years ago....... More info:.....
http://en.wikipedia.org/wiki/Freeplay_Energy
JG Jackson
"Uva Uvam Videndo Varia Fit"
PostPosted: May Tue 01, 2012 12:20 am
Do not open this radio. I have done it once and the spring exploded and gave me a terrible cut on the hand. It could have been an eye.
Dale
http://www.dalesantiqueradio.com/
PostPosted: May Thu 03, 2012 5:01 pm
I bought one from the GW and it had a spring issue. The end where it connects broke, but I repaired it.
Yes, be VERY careful if you open the generator/spring assembly.
The circuitboard is really small, and I doubt there is any schematic info available.
Gary Rabbitt
Post New Topic Post Reply  [ 4 posts ]  Moderators: sofaslug, Paul
