It is currently May Sat 25, 2013 10:46 pm
 Post subject: Need dial string guide for Motorola 52X table model
PostPosted: May Mon 07, 2012 3:25 am
Any suggestions as to where to look?
 Post subject: Re: Need dial string guide for Motorola 52X table model
PostPosted: May Mon 07, 2012 5:34 am
I have the Sams Dial Cord Stringing Guide from years 1938 - 1947 it does not show the model 52X but does have models 52C and all 51 - 53 mostly A C version using the same dial sting setup #73. Looks like it may be a simple setup. One string in is contect to large tuning pully and wraps around the small pully 1 1/2 turns, them back up to the large pully attached to a tension spring. If you have only two pullys this may work for you I can scan the drawing if you like and post it here for you
Jim
PostPosted: May Mon 07, 2012 3:16 pm
Yes, ssend to deltysdal@aol.com
PostPosted: May Fri 11, 2012 8:27 am
Can someone post a diagram of the set up.
Post New Topic Post Reply  [ 4 posts ]  Moderators: sofaslug, Paul
Users browsing this forum: Bob Masse, J. Hill, JerryHawthorne and 9 guests
