| Author |
Stevel
Post subject: GE J-805 Completed Posted: May Tue 29, 2012 2:01 am |
Joined: Nov Sat 13, 2010 5:00 am Posts: 511 Location: Woodinville, WA 98072
| Top |
Chuck McB
Post subject: Re: GE J-805 Completed Posted: May Tue 29, 2012 2:37 am |
| Top |
pred
Post subject: Re: GE J-805 Completed Posted: May Tue 29, 2012 3:49 am |
Joined: Jan Sun 24, 2010 10:52 pm Posts: 3780 Location: Phila Pa
That has gotta be a different radio ! You did great work! Peter
| Top |
philcolynn
Post subject: Re: GE J-805 Completed Posted: May Tue 29, 2012 4:33 am |
Joined: Feb Mon 27, 2012 5:56 am Posts: 787 Location: St. Cloud, Minnesota
Wow, Great job all the way arround!!!!! With what little you had to work with it come out fantstic!! Congrats!!! Lynn
| Top |
JerryHawthorne
Post subject: Re: GE J-805 Completed Posted: May Tue 29, 2012 5:13 am |
Joined: Feb Sun 24, 2008 4:21 am Posts: 2042 Location: Sedona, AZ
Just amazing what you accomplished. Congrats! Jerry
_________________ A friend in need is a pest. Bill Slee ca 1972
| Top |
ronnyradio
Post subject: Re: GE J-805 Completed Posted: May Tue 29, 2012 12:07 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 288 Location: Seminole, Florida
Absolutely amazing transformation! Thanks for sharing with us
| Top |
Mike C.
Post subject: Re: GE J-805 Completed Posted: May Tue 29, 2012 8:38 pm |
Joined: May Sun 06, 2007 2:52 am Posts: 1364 Location: New Hampshire, 03262
Very nice job on the J-805,Steve.I wish I had the ambition to go whole-hog like that on my J-105,but I tend to be a fixer-upper more than a full-fledged restorer.
I thought I would mention what I did with my completely trashed "Beam-A-Scope" in case anyone is interested in trying it with one of the many GE consoles(and other brands) that use them.I had considered leaving the antenna windings exposed as you did on the 805,but I had a lucid moment and came up with an idea.
My next door neighbor was installing some concrete piers for a deck to sit on.I noticed the cardboard, cylindrical "Sonotubes" he was using as forms,and the idea hit me that one of those would work great for a Beam-A-Scope housing.
I cut the tube to the appropriate length.I was able to re-use the top and bottom cardboard caps of the original housing,but they were slightly too small.So,I made a couple of "bushings" from the leftover chunk of Sonotube.I glued in the bushings and the bottom cap,installed the antenna coils and its backboard,and glued on the top cap.
For some reason I thought it would look good painted flat black,so I did just that.I then cut out the emblem from the old antenna and glued it to the new tube.I wish the crease wasn't there,but it still looks pretty good.
| Attachments: |
| Top |
Stevel
Post subject: Re: GE J-805 Completed Posted: May Tue 29, 2012 9:26 pm |
Mike C. wrote: Very nice job on the J-805,Steve.I wish I had the ambition to go whole-hog like that on my J-105,but I tend to be a fixer-upper more than a full-fledged restorer.
I thought I would mention what I did with my completely trashed "Beam-A-Scope" in case anyone is interested in trying it with one of the many GE consoles(and other brands) that use them.I had considered leaving the antenna windings exposed as you did on the 805,but I had a lucid moment and came up with an idea...<snip> Mike, your restoration of the Beam-A-Scope makes for a much more original look. Good job! I will probably go that same route on the next similar restoration. Excellent tip Steve
| Top |
bigblue72
Post subject: Re: GE J-805 Completed Posted: May Tue 29, 2012 10:51 pm |
| Member |
Joined: Feb Fri 24, 2012 12:12 am Posts: 258 Location: Rhode Island
Ouch, that resto job is so nice it hurts. Its nice to see basket cases returned to former glory. I can only imagine the joy the family felt to see it new again. This is what the hobby is truly about. Nice job, steve.
_________________ Truth is stranger than fiction.
| Top |
radiopicker
Post subject: Re: GE J-805 Completed Posted: May Tue 29, 2012 11:29 pm |
| Member |
Joined: Aug Thu 18, 2011 4:48 am Posts: 2496 Location: Stamford, NY
BEAUTIFUL job! I can't believe it's the same radio. Very nice work!!! Quote: I can only imagine the joy the family felt to see it new again. This is what the hobby is truly about. Nice job, steve. +1
_________________ Vincent
| Top |
Ken G
Post subject: Re: GE J-805 Completed Posted: May Wed 30, 2012 2:10 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 14574 Location: ID 83301
You guys need to send all of your cabinets to this guy so he can restore them just like that . Amazing .
| Top |
dberman51
Post subject: Re: GE J-805 Completed Posted: May Wed 30, 2012 2:42 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2307 Location: Boston, MA USA
An incredible job of restoration. Excellent work! Looks like it just came off the production line. It's a very handsome set too. It seems to have the same chassis as the J-105, and if it sounds anything like it, it will be fantastic.
-David
| Top |
dberman51
Post subject: Re: GE J-805 Completed Posted: May Wed 30, 2012 2:48 am |
Mike C. wrote: My next door neighbor was installing some concrete piers for a deck to sit on.I noticed the cardboard, cylindrical "Sonotubes" he was using as forms,and the idea hit me that one of those would work great for a Beam-A-Scope housing.
For some reason I thought it would look good painted flat black,so I did just that.I then cut out the emblem from the old antenna and glued it to the new tube.I wish the crease wasn't there,but it still looks pretty good. Mike, this was a brilliant idea. The Beam-A-Scope is still intact on my set but this is something clearly to keep in mind for the future. -David
| Top |
Jack Shirley
Post subject: Re: GE J-805 Completed Posted: May Wed 30, 2012 3:14 am |
| Member |
Joined: Mar Fri 14, 2008 1:40 pm Posts: 8406 Location: SE USA
Good example of perseverance. I bet you have countless hours in that project. Great job!
_________________ The beatings will continue until the morale improves
| Top |
Stevel
Post subject: Re: GE J-805 Completed Posted: May Wed 30, 2012 2:22 pm |
| Top |
Stevel
Post subject: Re: GE J-805 Completed Posted: May Wed 30, 2012 2:24 pm |
dberman51 wrote: An incredible job of restoration. Excellent work! Looks like it just came off the production line. It's a very handsome set too. It seems to have the same chassis as the J-105, and if it sounds anything like it, it will be fantastic.
-David David, the dial glass I used is actually from a J-105, so the chassis must be the same, or very similar. You are correct, it sounds very good. Excellent bass from that big 'ol speaker. Steve
| Top |
Mike C.
Post subject: Re: GE J-805 Completed Posted: May Wed 30, 2012 11:06 pm |
dberman51 wrote: [. Mike, this was a brilliant idea. The Beam-A-Scope is still intact on my set but this is something clearly to keep in mind for the future. -David[/quote] Thank you,David.
| Top |
Mike C.
Post subject: Re: GE J-805 Completed Posted: May Wed 30, 2012 11:38 pm |
Stevel wrote: [David, the dial glass I used is actually from a J-105, so the chassis must be the same, or very similar. You are correct, it sounds very good. Excellent bass from that big 'ol speaker.
Steve Yup,the 105 and the 805 use the same basic chassis.My 105 had a lot of broken bakelite trim and I got those parts from a fellow parting out an 805. The main differences between the two radios appears to be 2 fewer pushbuttons on the 805 and the 105 also has a 61/2" speaker as well as the 14". Also the 105 is a 10 tube set vs. the 805's 8 tubes.However,GE was pretty sneaky about how they accomplished the higher tube count.They broke up the DET,AVC,FIRST AUDIO functions into a bunch of individual 6J5s.Both radios use 6V6s in push/pull. GE also claimed that the 105 put out 4 more watts of "undistorted power" than the 805,but I don't see how that can be myself.
| Top |
dberman51
Post subject: Re: GE J-805 Completed Posted: May Wed 30, 2012 11:47 pm |
Mike, I just took a look at the schematic for the J-805. There are a couple of major differences in the amplifiers. The J-105 has negative feedback while the 805 does not, and the output stage B+ is significantly higher on the 105 than the 805. This alone would account for the higher output power rating on the J-105.
-David
| Top |
Mike C.
Post subject: Re: GE J-805 Completed Posted: May Wed 30, 2012 11:58 pm |
dberman51 wrote: The J-105 has negative feedback while the 805 does not.......
-David I see...the old "negative feedback' trick again,as Maxwell Smart would say.
| Top |
