| Author |
fifties
Post subject: Re: What year did Radio companies start to switch from Bakel Posted: Jul Wed 04, 2012 10:02 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8763 Location: SoCal, 91387
mcpherjc wrote: I asked the inital question because I see many radio's listed for sale that I am fairly sure are plastic (modern day plastic like that used in childrens toys) say bakelite and also some that I am fairly sure are Bakelite say that they are plastic. Often these same radios will list a year that they were made so I was curious if the date could be a better guide to determining which one they are. As was pointed out, the transition didn't just occur overnight, but over a period of years. Most of the Bakelite cabinets I've seen are either painted over -usually in off-white- or naturally Chocolate in color, other than Catalan sets, so that's one assist in determining. Another is touching the inside of the cabinet with a soldering iron, to see if it causes a distortion; in Bakelite it won't, plastic it will (hence my previous suggestion about newer miniature tubes not requiring a Bakelite cabinet, but able to reside in a plastic one with no effects to it. The white craze seen on the left top of many Bakelite radios was caused by the intense heat emitted by the GT audio output tube...No such problem existed with it's junior replacement). Nor have I seen metal or Asbestos heat shields in miniature tube circuits, as were used in some of the GT chassis.
_________________ *******\\\\\\\\\******He Who Dies With The Most Radios Wins******/////////*******
| Top |
dberman51
Post subject: Re: What year did Radio companies start to switch from Bakel Posted: Jul Wed 04, 2012 10:14 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2309 Location: Boston, MA USA
fifties wrote: The white craze seen on the left top of many Bakelite radios was caused by the intense heat emitted by the GT audio output tube...No such problem existed with it's junior replacement). Nor have I seen metal or Asbestos heat shields in miniature tube circuits, as were used in some of the GT chassis. Please stop repeating this misinformation. Two people have already informed you that it is incorrect. Tube heat dissipation in AA5 sets is exactly the same whether the set uses the octal 12SA7, 12SK7, 12SQ7, 50L6, 35Z5 line-up or the miniature 12BE6, 12BA6, 12AV6, 50C5, 35W4 line-up. If you don't believe us, please just check the RCA tube manual for heater ratings and cathode current in typical operation. You will note that they are equal. -David
| Top |
fifties
Post subject: Re: What year did Radio companies start to switch from Bakel Posted: Jul Wed 04, 2012 10:47 pm |
| Member |
dberman51 wrote: fifties wrote: The white craze seen on the left top of many Bakelite radios was caused by the intense heat emitted by the GT audio output tube...No such problem existed with it's junior replacement). Nor have I seen metal or Asbestos heat shields in miniature tube circuits, as were used in some of the GT chassis. Please stop repeating this misinformation. Two people have already informed you that it is incorrect. Tube heat dissipation in AA5 sets is exactly the same whether the set uses the octal 12SA7, 12SK7, 12SQ7, 50L6, 35Z5 line-up or the miniature 12BE6, 12BA6, 12AV6, 50C5, 35W4 line-up. If you don't believe us, please just check the RCA tube manual for heater ratings and cathode current in typical operation. You will note that they are equal. -David You seem to have ignored, Quote: Nor have I seen metal or Asbestos heat shields in miniature tube circuits, as were used in some of the GT chassis and I would be interested in your explanation on the cause of white haze on the top left side of some GT tube sets. Your information will be appreciated.
| Top |
oldradioparts
Post subject: Re: What year did Radio companies start to switch from Bakel Posted: Jul Thu 05, 2012 1:23 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2868 Location: 253 Blanche St. Plymouth, MI USA
Dave, you have indeed educated us all here... Celluloid seems to be the real "first plastic" and I will never say Bakelite was again ! Whats amazing is how the explosion of plastics seemed to happen during WW2. Mark Oppat www.oldradioparts.net
| Top |
ggregg
Post subject: Re: What year did Radio companies start to switch from Bakel Posted: Jul Thu 05, 2012 2:19 am |
Joined: Aug Sun 01, 2010 1:12 am Posts: 5227 Location: Minnesota
One tip not discussed yet is cleaning. Bakelite can handle just about anything but plastics can be very sensitive to strong cleaners, or products that can be used as cleaners. Don't ask me how I know.......
| Top |
mcpherjc
Post subject: Re: What year did Radio companies start to switch from Bakel Posted: Jul Thu 05, 2012 4:58 am |
| Member |
Joined: Jun Sun 03, 2012 8:21 pm Posts: 541 Location: APO AP
Personally I think the Bakelite is superior to modern plastic because other than being a little on the brittle side it seems much more durable.
_________________ Mac
Zenith Crosley GE Philco RCA
| Top |
oldradioparts
Post subject: Re: What year did Radio companies start to switch from Bakel Posted: Jul Thu 05, 2012 6:02 am |
Bakelite is VERY durable. You can use paint strippers on it. It doesnt shrink or warp. Some of it seems to oxidize on the surface and loose its "finish" which I am not sure you can ever really get back. However, it was a bit toxic to make... so the workers suffered. By the mid 50's the other plastics had taken over. Mark Oppat www.oldradioparts.net
| Top |
mcpherjc
Post subject: Re: What year did Radio companies start to switch from Bakel Posted: Jul Thu 05, 2012 6:09 am |
| Member |
Since it was mentioned. When you get the Bakelites with that white haze on it, you see this a lot with the dark brown ones, is there anything that can get that off without damaging the bakelite?
| Top |
Robert Lozier
Post subject: Re: What year did Radio companies start to switch from Bakel Posted: Jul Thu 05, 2012 12:31 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 228 Location: Monroe, NC 28112 USA
The white haze you see on dark Bakelite is most likely the exposed filler. The Bakelite is not 100% resin, a filler and pigments make up a significant percentage. A popular filler was finely ground walnut shells.
What has happened is that the resin at the surface has been dissolved or worn away... The most common mistake made by folks wanting to clean up Bakelite cabinets is using caustic cleaners like Fantastic, Super Clean, Purple Stuff, etc. You know that you are using such cleaners when a white cloth turns yellow/brown.... That is the resin going into solution.
The cure then is stain and lacquer or just lacquer paint... Only clean Bakelite with regular Goop or Go-Jo.
Robert
| Top |
mcpherjc
Post subject: Re: What year did Radio companies start to switch from Bakel Posted: Jul Thu 05, 2012 2:40 pm |
| Member |
When you say stain do you a same type of stain that you would use on wood? Thanks.
| Top |
Robert Lozier
Post subject: Re: What year did Radio companies start to switch from Bakel Posted: Jul Thu 05, 2012 4:46 pm |
I have used black or walnut analine dye stain and and a thin overcoat of clear lacquer. If I don't like the results, I move to black lacquer OR just live with the haze..
Robert
| Top |
codefox
Post subject: Re: What year did Radio companies start to switch from Bakel Posted: Jul Thu 05, 2012 7:53 pm |
When supplies dried up and cheaper alternatives became available. Late 40's early 50's.
| Top |
Users browsing this forum: murceratbat and 7 guests |
