It is currently Jun Thu 20, 2013 11:24 am
 Post subject: Magnavox Stero Console Record player. HELP!
PostPosted: Jul Sun 15, 2012 9:57 pm
I need some help from the pro's. I have a hand me down Magnavox Record and Stereo. The only real info I have on it is that it was purchased in the early 70's for over $400.
Some of its markings I can find is that its a French Provisional -3768.
Can ANYONE help me and tell me if this thing has some value at all? It works and has a nice sound. Seems that the turntable is a tad bit slow and needs some adjustments. Other than that, all is good.
Can someone give me a little history on this and its value, please. Its my grandfathers.
I have pictures, but they have made it where i cant upload an attachment, so i can email them if need to see it.
Thanks again!
Kelly
 Post subject: Re: Magnavox Stero Console Record player. HELP!
PostPosted: Jul Sun 15, 2012 10:38 pm
Basically you will need to clean + lube the record changer, replace all electrolytic capacitors then clean all controls and switches. Should work very good after that.
PostPosted: Jul Sun 15, 2012 10:48 pm
kkovardfd wrote:
Repair Tech-
Adjustments, tune up, overhaul.. All the same. I'm sorry I didn't think to use the correct terminology such as overhaul as we know you are the pro! So excuse my terminology. Anyone else like to give an answer without a snooty answer. Geez.
What a nice welcome.
Don't feel bad, he considers everyone else here "home tinkerer's" and is not shy about saying it. I just ignore that sort of thing, it's common to the internet, and kind of amusing.
On the other hand, he isn't entirely wrong. The record player will likely need a pretty serious cleaning, relubrication, and careful reassembly and adjustment to work at its best, and the electronics should probably be reworked to some extend for long-term reliable operations. Turntables are the worst, with lots of mechanical bits that tend to be unique and thus it's very difficult to find replacement parts. Most electronic parts are easy to find.
As a far as value, it's not very valuable. Maybe $100 if you find the right person in the right place, but many times these sets wind up in a dumpster since they can be hard to give away. That's says nothing about whatever sentimental value it might have to you, which no one else can judge.
If you want to pursue restoration, this is definitely the right place to come, the collective knowledge of the people here is just astonishing. Might have to put up with a curmudgeon or two, that happens when the average age is ~60...
Brett
PostPosted: Jul Sun 15, 2012 11:18 pm
Lube and Brett- thanks so much for the polite response.
PostPosted: Jul Sun 15, 2012 11:21 pm
Also, I have probably 150-200 records. Anyone know a good site to check their value? Lots from the 50's-60's.
PostPosted: Jul Sun 15, 2012 11:45 pm
if you have joined this forum you will need a pass word ok , then go to Photo Gallery link close to top of most all pages , then make sure you are loged in with your pass word then go to right album and up load your pictures or you can even post them in last album Called TEMP album put the pictures in it for unknown radios or things
http://s693.photobucket.com/albums/vv293/dahilderbrand/
PostPosted: Jul Mon 16, 2012 12:17 am
Welcome, some people use this,http://www.popsike.com/.Here in the Denver area, there are still stores the sell vynal, old and new, and equipment to play it on.
PostPosted: Jul Mon 16, 2012 12:37 am
You're welcome.
I forgot to mention that the AM and FM tuners will more than likely need an alignment. I recommend not doing anything until you get the service manual.
Post New Topic Post Reply  [ 8 posts ]  Moderators: sofaslug, Paul
