It is currently May Sat 25, 2013 4:20 pm
 Post subject: Dial tuning knob moves very stiffly
PostPosted: Aug Sat 23, 2003 3:52 am
Location: Buckingham County, VA. (Foothills of the Blue Ridge Mtns)
Could be anything in the tuning path, i.e. pulley, pointer, etc. Try a small amount of WD40 on the pulley bearing(s) and also on the tuner shaft itself. Sometimes the lubrication on the tuner bearing will dry out causing it to bind. Make sure you keep the lubricant away from the dial cord as this could cause other problems.<P>------------------<BR>
Post New Topic Post Reply  [ 3 posts ]  Moderators: sofaslug, Paul
Users browsing this forum: azenithnut, Exabot [Bot], NewarkBob and 12 guests
