It is currently Oct Tue 16, 2018 1:47 pm
 Post subject: RCA 8x541
PostPosted: Dec Sun 03, 2017 7:55 pm
Hi: I am a newbie to this hobby, and have been working on an RCA 8x541. I have replaced most of the caps and test run it on a Variac. Before recapping, it had a loud hum, which is now gone. Unfortunately, all I hear now is a very low hum, with occasional lightning storm type static.
After reading on this forum, it seems that in addition to whatever other problem it has, it may have the dreaded SMD. If this is the case, do I even want to continue to try and repair it?
I don't want to sink a lot of time and money into it if the results won't be satisfactory.
Thank you for your advice.
 Post subject: Re: RCA 8x541
PostPosted: Dec Sun 03, 2017 8:23 pm
Yes you could have the SMD on this model. Check the secondary voltage on IF cans while the static happens. If you see spikes of voltage you have SMD. Can be repaired cheap with some new caps after you remove the mica sheets.
PostPosted: Dec Sun 03, 2017 10:43 pm
Thank you for the reply. So I would check the voltage across the secondary terminals of the IF, or from chassis to terminal on the IF? I am new to this and probably don't know some of the basics. But I am learning a lot.
I imagine there must be a write-up on this repair here on the forum somewhere.
Thank you again.
PostPosted: Dec Mon 04, 2017 12:05 am
There are lots of helpful videos on YouTube showing SMD repairs. Just search for "SMD" or "silver mica disease".
PostPosted: Dec Tue 05, 2017 12:46 am
Read with DC meter low scale from negative end from filter capacitors to secondary of of both IF cans. Any spiking DC reading indicates a voltage leak. SMD.
PostPosted: Dec Tue 05, 2017 2:47 am
Here's a go-to-video for... Replacing mica capacitors in an AA5 I.F. transformer.
viewtopic.php?p=2765766#p2765766
Should you require a couple of spares, both I.F. transformers can be found here $7.00 ea
http://www.oldradioparts.com/2a6fla.txt ←page was updated on January 1st, 2017 !
search for RCA 73036 and RCA 73037 on the above page using keyboard shortcut
Ctrl+F on a PC Cmd+F on a Mac
homepage: http://www.oldradioparts.com/
Schematic: http://www.nostalgiaair.org/Resources/243/M0015243.htm
high-resolution schematic: http://americanradiohistory.com/hd2/IDX ... e-0280.pdf
PostPosted: Dec Wed 06, 2017 1:05 am
Thank you very much!
Post New Topic Post Reply  [ 7 posts ]  Moderator: sofaslug
Users browsing this forum: bruce47 and 18 guests
