It is currently Oct Sat 20, 2018 4:57 am
 Post subject: look for a wiring diagram for RCA C-15
PostPosted: Dec Tue 05, 2017 1:52 am
Hi picked up a new toy.. it claims to be a RCA Hazeltine C-15 apx 1934 -1937.... I ran though riders and could not come up with it..please help :shock:
 Post subject: Re: look for a wiring diagram for RCA C-15
PostPosted: Dec Tue 05, 2017 2:14 am
The tag says Automatic Radio Mfg. Co. That's your manufacturer. It's an Automatic C-15.
The mentions of RCA and Hazeltine are just license notices... That's who Automatic was paying royalties to, to use their radio patents.
Rodney -- KG7EPW
PostPosted: Dec Tue 05, 2017 2:19 am
That's not an RCA radio. That radio was manufactured by the Automatic Radio Mfg. Co. of Boston, Mass. The tag states that this radio uses technology of which RCA has licensed Automatic to use. The C-15 model designation is correct.
Michael Feldt
www.indianaradios.com
PostPosted: Dec Tue 05, 2017 2:23 am
I find nothing under Automatic that looks even remotely similar.....and nothing for a C-15 except this:
http://radioatticarchives.com/radio.htm?radio=8533
Please post the tube types, a closeup of the dial, and a rear view showing the innards.
(The dial actually looks RCA-ish....)
-Mark http://pixellany.com
PostPosted: Dec Tue 05, 2017 2:33 am
Cool.....Ill look that up Thanks :lol:
The tubes are 6A7, 6D6, 75, 43,25Z5, K49C
PostPosted: Dec Tue 05, 2017 2:47 am
That tube lineup is as common as dirt, but the ballast narrows it way down:
http://www.grillecloth.com/sylvania/tub ... ubmit&db=5
only one automatic on the list, but I can't find it anywhere---nothing else on the list looks close.
How about a **readable** picture of the dial?---looks like you need some disassembly for that
PostPosted: Dec Tue 05, 2017 2:56 am
I linked that data base.. thanks that will help in other projects
PostPosted: Dec Tue 05, 2017 12:49 pm
It looks like there's a name on the dial face. If there is, what is the name?
Michael Feldt
PostPosted: Dec Wed 06, 2017 11:59 pm
this does not say much
PostPosted: Dec Thu 07, 2017 3:38 am
You might be surprised.....that is a pretty distinctive graphic---someone may recognize it.
PostPosted: Dec Thu 07, 2017 4:28 pm
Look at this:
https://www.radiomuseum.org/r/westinghou_wr101.html
the grillecloth site list the WR103 as having the right tube lineup, but it does not look anything like yours.
So--maybe look up the Rider's info for both Westinghouse and Bosch (Bosch made some of the Westinghouse models)
PostPosted: Dec Fri 08, 2017 12:22 am
The very different Automatic radio posted at the radio attic might be mis-identified as a C-15. The label looks like it may actually say C-12?
The critter on the 'coat of arms' may be a lion, but it has no mane, so is it a female? A cougar, or a panther? Maybe just a wiener dog. :lol:
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Dec Fri 08, 2017 1:04 am
BIngo---there is that graphic!!
PostPosted: Dec Fri 08, 2017 7:06 am
I have a copy of WR103.... its very close, it has the right tube match plus the K49C is wired the same as the WR103....so I may have to use that as a reff...... :roll:.......Look at the WR101 and it looks closer..... I'm going to check them both out and see whos closer
PostPosted: Jan Fri 05, 2018 5:22 am
After pulling my hair out, in trying to located a wiring diagram for a automatic c-15... it was found that this diagram is the same as Automatic 1936 S-6, with out the 2nd IF can....
Post New Topic Post Reply  [ 15 posts ]  Moderator: sofaslug
Users browsing this forum: allied333, geostep, Google [Bot], lorenz200w and 18 guests
