It is currently Jul Fri 20, 2018 9:54 am
 Post subject: Atwater Kent Model 55C - "muddy" sound
PostPosted: Dec Fri 08, 2017 1:39 am
My A-K 55C is working, but i have noticed that the sound is a bit "muddy" rather than sharp and clear. This is especially noticeable when I am playing music through an AM transmitter in the house, which sounds fine over other radios. The only things I have replaced, as far as components go, are the power supply capacitors and the line voltage caps. The "quality capacitor" was left in place. The tubes that have shields, have the shields in place, but the sheet metal cover that fastens in place with thumb nuts is missing. What could cause that "muddy" sounding audio? Where should I look first? And if it is the "quality capacitor", is there any way to disconnect it without digging into a tar block?
 Post subject: Re: Atwater Kent Model 55C - "muddy" sound
PostPosted: Dec Fri 08, 2017 2:01 am
...Or, maybe I have the drive turned up too far on my transmitter?
PostPosted: Dec Fri 08, 2017 2:29 am
As with all vintage sets, you must replace ALL waxed paper capacitors.
These are located in two rectangular metal cans screwed to the chassis walls.
The late version has a third metal can containing two line bypass caps.
PostPosted: Dec Fri 08, 2017 11:46 am
I was never pleased with the audio quality from my 55C.
Even listening to news or baseball games on the AK, listening fatigue occurs pretty quickly.
I have the same issue with my circa 1935 GE/RCA console.
Regards - Dan
Dan
N3DTF
PostPosted: Dec Fri 08, 2017 1:39 pm
Agree with Leigh.
Have you replaced all bypass, coupling, and filter caps yet?
Its no small job due to the caps all being sealed in metal cans, but once completed it makes a world of difference in sonic quality.
Here is a picture of capacitor cans being restuffed.
Paul
...... how hard can it be?
PostPosted: Dec Fri 08, 2017 2:04 pm
Not overlooking that that can is not completed I would, if no lining the can preferred to see shrink tube, or a sleeve on the wires on the top cap to ensure no shorting to the side.
As the originals may have been "outside foil"; I tend with modern caps like that in close proximity to shield them to prevent induction. I do it, as I have seen induction happen.
Marc
PostPosted: Dec Fri 08, 2017 2:59 pm
My A-K 55C is a late model. I replaced all the filter caps in the big square can on top of the chassis ( they were small enough to mount UNDER the chassis on a terminal strip, in fact). It originally had three of the "sardine cans" under the chassis, but at some time in the radio's working life, someone replaced the line cord bypass caps with a couple of paper and foil ones (looked like 1930's or 1940's vintage ones) and eliminated that "can" altogether. I replaced those caps with a couple of X/Y rated ones, which are safer for line bypass use (if they fail, they "open" short).
I have not, however, touched the other two "sardine cans" under the chassis (they would be the middle and right hand ones, if you are looking at the underside of the chassis with the cans at the upper edge). The line bypass caps would have been in the (now missing) left hand can.
PostPosted: Dec Fri 08, 2017 3:35 pm
Seems to me just about all the old TRF sets I have worked on don't have the real clear sound we get from a more modern superhet radio that has AVC and diode detection.
PostPosted: Dec Fri 08, 2017 3:49 pm
Have you done the obvious stuff like measuring the B+ voltage, grid bias voltages for the audio driver and output tubes, and testing the detector and three audio stage tubes for emission? Low B+ voltage, incorrect grid bias voltage (which can be a byproduct of low B+ voltage) and low tube emission can trash the sound quality, either singularly or in concert with each other. An incorrectly-rebuilt, contaminated, or damaged, speaker can also be the source of poor sound quality. The simplest way to check this is to disconnect the voice coil (only) of the A-K speaker and patch in a PM speaker of known functionality.
PostPosted: Dec Fri 08, 2017 4:04 pm
Voltages are within reasonable specs - checked that when I first replaced the PS filter caps. The radio had a 1930's vintage speaker installed when I first got it, and I replaced it with an F4. The F4 sounds better than the other one, probably because the field coil has a different resistance.
PostPosted: Dec Fri 08, 2017 8:49 pm
Those are waxed paper caps, and MUST be replaced like any others of that vintage.
Paul showed a nice photo of the proper method.
You can solder the base plate back in the can after replacing the caps, but that's not mandatory. If you do, it only needs solder in a couple of spots, not all the way around.
PostPosted: Dec Fri 08, 2017 8:51 pm
Hi Lou,
The AK 55 has a proper detector circuit, but of course no AVC.
It certainly is not a hi-fi receiver.
PostPosted: Dec Fri 08, 2017 9:00 pm
My experience with the 55 is to replace the caps in the "sardine" cans. Be mindful of the contents of the can that couples the plate circuits of the detector. Wrong component values here can result in poor audio characteristics. I have found discrepancies there and opted to duplicate the contents. The cans are numbered and there is data for the contents. The AC bypass can should be replaced if there are holes in the chassis provided. Please use a can numbered for the bypass and engrave numbers if a sub. can is used. By replacing the can there is less a chance for induced AC hum, dress any AC leads close to chassis, if there are a pairs of AC leads, twist them together 1 turn/inch.
There are many wire wound resistors in the chassis, they terminate to a hollow rivet and often have a poor connection. Remove screw from resistor and crush the rivet with pliers to remake the connection.
There is a pair of bias resistors in the B- return that shunt the speaker field. These often change value and may be unstable under current flow. Be sure to use at least 1 watt resistors, standard 10% vales will be close enough. Check the bias on the 45's, too negative will reduce output, too little bias will consume a lot of plate current and there will be distortion and HOT 45's. By altering the values of the bias resistors a good compromise can be found. The 45's will run warm but not hot to touch. Be concerned that the total value of the two bias resistor remains the same as published.
Some chassis returns are via a rivet to the chassis, after 80 years these often corrode even though it is not visible and does not indicate a poor connection with a typical ohmmeter. Solder all such chassis grounds to be sure, use a high wattage iron and an aggressive flux. If in doubt of skills, drill out hollow rivet and replace with machine screw and toothed lock washers...
The is a gimmick capacitor for the local distance circuit. this capacitor is made from two specific lengths of enameled magnet wire, twisted together a specific amount then covered with varnished cambric with a solder lug. It looks like a shabby piece of hookup wire... If it has been replaced with a wire, make a replica or plan to install a replacement series cap, FWIR the value is around 10 to 20 pf.
IMHO a TRF receiver is capable of good fidelity if working properly and does not have the narrow bandpass of a superhetrodyne. Like any other receiver, components and connections must be in good condition.
YMMV
PostPosted: Dec Fri 08, 2017 10:14 pm
I found at least PART of the problem. Remember in my first post I said it was especially noticable when I used an AM transmitter? The transmitter is a 12AT6/12CS6 one I built from a kit offered in this forum a few years ago. I had the gain control turned way up to try to drown out the RF noise in the house from appliances, CFLs, and the WiFi. Modern radios don't seem to notice it as much, but in the AK, and even in my Radiola 60, as it turns out, it is WAY overmodulated. Turned the "volume" on the transmitter down - lots more static now, but not so muddy sounding. I will still replace the caps in the cans, though, eventually.
PostPosted: Dec Fri 08, 2017 11:35 pm
Overhauling the set really is a must, the best you can get out of it will be when it is in spec & leaking caps do nothing to help, especially coupling ones. Being a radio one can always put an antenna on it & see what a Radio station sounds like. Where a DX switch was missing on an hacked STC here, I found 68pF switched into series with the antenna ideal. Distortion being gauged with an Oscilloscope.
Whist it is not likely to be causing the Muddy sound, which a speaker can be involved in, just like a Superhet they do need calibration when there are a series of tuned circuits, to ensure that they are all on the same frequency.
RFI is out of control & I am firmly of the opinion that the regulators both here and there, have reached the point of being ineffective. I would add that I have had two LED flood lights that I took back to point of sale for drowning out everything Radio on AM & FM.
Where there is a transformer in the set some improvements might be had by grounding the set & organizing line caps to go to it? RFI from power lines here is bad & lightning just as interesting. It is at the point where several power boards have been "got at" to deal with it. I also have plug in devices to remove line RF & deal with surges: That I have mentioned before.
If you build such devices, I suggest a well grounded metal, or fire rated box, as MOV's are known to explode.
Marc
PostPosted: Dec Fri 08, 2017 11:44 pm
Thanks for all the advice. I will have to see what I have for caps in my parts box.
One other question: I do not have a ground hooked to my radio, and it receives without it. First, will it perform better with a ground wire? And second, since all the wiring in our house goes to plastic outlet boxes, the old "center screw ground connection" is not an option. What can I do for a ground, instead?
PostPosted: Dec Sat 09, 2017 12:15 am
It doesn't matter that the boxes are plastic. In a 3 wire system the ground wire is attached to the socket which carries that ground to the screw terminal on the plate.
PostPosted: Dec Sat 09, 2017 12:40 am
Try this: detune the set slightly one way or the other. This might pick up the sidebands better.
Doug
PostPosted: Dec Sat 09, 2017 12:59 am
I thought I would reply to this and let you know that Paul dose some really good work. I had him recap my big can on my 55 and my radiola 60. due to a hand injury I received and was very pleased with the result and quality of his work
Benny
PostPosted: Dec Sat 09, 2017 1:21 am
so if I understand this the quality control cap is built into the speaker
Post New Topic Post Reply  [ 36 posts ]  Moderators: Marcc, Norm Leal Go to page 1, 2  Next
Users browsing this forum: Google [Bot], lorenz200w, mrbee and 12 guests
