Antique Radio Forums
http://antiqueradios.com/forums/
1942 Allied (Knight Kit) Ocean Hopper - Need Information
http://antiqueradios.com/forums/viewtopic.php?f=1&t=333316
Page 1 of 1
Author:  bcascisa [ Dec Fri 29, 2017 10:06 pm ]
Post subject:  1942 Allied (Knight Kit) Ocean Hopper - Need Information
I acquired an early (about 1942) version of the Allied Radio Ocean Hopper receiver.
It is the version with the 70L7GT and the 12SJ7.
I have searched the web to the best of my ability and can only come up with later versions of the Ocean Hopper.
Does anyone have any information on this model?
Thanks in advance.
Author:  VEK [ Dec Sat 30, 2017 2:27 am ]
Post subject:  Re: 1942 Allied (Knight Kit) Ocean Hopper - Need Information
Send me your Email address by PM, I can scan and send you some info. Probably tomorrow evening.
Vince
Author:  bcascisa [ Dec Sat 30, 2017 6:35 am ]
Thanks Vince - That was exactly what I needed.
ARF comes through again.
Author:  SkyKing [ Dec Sat 30, 2017 7:01 pm ]
Show us the innards!!
Author:  bcascisa [ Dec Sat 30, 2017 8:29 pm ]
Sky King,
Here is a shot of the "innards" as found.
Author:  bcascisa [ Dec Sat 30, 2017 11:19 pm ]
Here it is as a work in progress and my redrawn schematic.
Author:  Mr. Detrola [ Dec Sat 30, 2017 11:31 pm ]
Really nice work, and a set which isn't often seen today.
Interesting that your original photos show many components under the chassis which are about two decades newer than the set itself, an indication that some previous owner kept it working for at least that long. Those Sprague capacitors with red writing, the ElMenco mica caps, and the Cornell-Dubilier electrolytics are types that were commonly seen in the 60's and did not exist until many years after the kit was sold.
Author:  Tim Tress [ Dec Sun 31, 2017 12:39 am ]
Shouldn't the feed to the rectifier plate connect to the other side of the filament resistor?
Author:  oldradiogeorge [ Dec Sun 31, 2017 2:06 am ]
Beautiful work! What is that 2 piece white block next to the variable cap, and the white component
marked N,L ?
Author:  bcascisa [ Dec Sun 31, 2017 2:09 am ]
Hi Tim,
You are correct.
I reverse engineered the schematic before I discovered what the set was.
It was connected as shown above.
In that configuration, I have about 106V of B+.
I will move it and see what that yields.
Author:  bcascisa [ Dec Sun 31, 2017 2:16 am ]
Hi oldradiogeorge,
That is the Line Input Filter shown in the schematic.
L & N are Line and Neutral.
I removed it from an IEN power input module.
It has "X" and "Y" safety capacitors and inductors as shown.
Author:  bcascisa [ Dec Sun 31, 2017 3:56 am ]
The two piece white blocks are two 470 Ohm 5W resistors in parallel.
Sorry I missed this in my previous response.
Author:  Geoff Fors [ Dec Sun 31, 2017 5:56 am ]
The schematic and wiring diagram together with instructions and parts list is in Allied's Radio Builder's Handbook, 8th ed. 1941. At page 26. This may be on the web somewhere? My scanner croaked for Christmas or I would put these pages here.
There is no line filter in the original, but you know that.
Hot side of line goes through a 50 Ohm resistor to the 70L7 plate pin. And through a 250 Ohm resistor to the heater pin of same. Filter caps were a pair of 16 mfd tubulars.
Complete kit without coils or tubes was $ 5.95 in 1941 .
Author:  oldradiogeorge [ Dec Sun 31, 2017 7:03 am ]
Thanks for the reply. I was confused because in the schematic, there appeared to be three separate tubes. So I
thought that there must have been an external power supply. After your replies, and reading the advertisement,
I now realize that the diode tube is in the 70L7 envelope, The power supply is all there, and you added the line
filter. I know this was commercially made, but this is the kind of stuff that I wish filled the Homebrew Radios and
Equipment section. (Your complete rewiring and additions practically make it a homebrew!)
Author:  bcascisa [ Dec Sun 31, 2017 8:11 am ]
I bought this at a swap meet for parts but upon examination it looked like a viable radio.
I initially thought this was a TRF and spent a lot of time searching the web for a "Two Tube TRF".
This radio has absolutely no markings of any kind.
It took me some time to figure out this was probably a kit from the 40's.
That led me to Allied Radio where I found the radio in the 1942 catalog.
That led to this thread.
Vince (above) sent me a scan of the pages from the Allied Handbook.
I have since found one on eBay and ordered it.
The radio had been modified and had parts replaced (most of the caps and some resistors).
In this incarnation I have replaced all of the caps and some of the resistors ... again.
I made a coil form and am about to wind a coil.
The coil information on the schematic is a best estimate based on other regen's I found on the web.
Below is the corrected schematic.
Author:  SkyKing [ Jan Wed 03, 2018 6:21 pm ]
Dave Ishmael – WA6VVL is probably the leading expert on anything related to Ocean Hoppers.
http://www.amdx.info/OH2.html
His email address is at the top of the page. He has always answered any questions I've had and can probably verify your coil information.
By the way, after scouring the 'net it seems like yours is the only PHOTOGRAPH of the two stage version out there.
Author:  bcascisa [ Jan Wed 03, 2018 9:10 pm ]
Thanks for the link skyking.
I found his restoration article during my search.
He does picture perfect work.
I love the "Square Wiring" :D .
I may drop him a line when I start winding coils.
Author:  shinkuukan [ Jan Thu 04, 2018 12:58 am ]
I think Allied should have stayed with this circuit rather than the later 12AT6, 50C5, 35W4 version.
Rob
Author:  bcascisa [ Jan Fri 05, 2018 3:25 am ]
Just as a curiosity I looked up all of the catalog entries for Ocean Hopper I could find.
Here is the table.
I also snipped all of the catalog entries for the kit.
Page 1 of 1 All times are UTC [ DST ]
