It is currently Jun Sat 23, 2018 8:56 am
 Post subject: Zenith 12S370
PostPosted: Jan Thu 11, 2018 1:48 am
I'll be into one of these in a couple of weeks and would like to have a legible parts list. Can anyone help out? It is so small in Riders that it might just as well be left out.
Bruce Hagen
Bruce Hagen
 Post subject: Re: Zenith 12S370
PostPosted: Jan Thu 11, 2018 3:18 pm
Did you get your copy of the schematic from Nostalgia Air? I think Radiomuseum has better scans available.
Jon
We are the only normal ones.
PostPosted: Jan Thu 11, 2018 6:32 pm
I have a high res PDF version of the schematic and can email you 3 PDF's of the parts list zoomed to 600% if you'll PM me with your email address.
PostPosted: Jan Thu 11, 2018 6:59 pm
Or..
--Try the American radio history site
--Get one of the Rider's CDs from EBay
There is another Rider's repository somewhere on the web..Google might know.
-Mark http://pixellany.com
PostPosted: Jan Sun 21, 2018 5:24 pm
Appreciate the help guys. I now have readable documentation which I badly needed as the chassis arrived yesterday and it is best described as brutalized. Now I'm looking for a pix of the top and bottom of the chassis as it left Zenith as it seems that this set deserves to live.
Thanks again,
Bruce Hagen
Bruce Hagen
PostPosted: Jan Tue 30, 2018 9:43 pm
Still looking for chassis photos. Also need a picture of the hardware that is missing. This hardware would connect the band changing shaft to the knob shaft. Even better does anyone have this hardware for sale? Thanks again.
Bruce Hagen
Bruce Hagen
PostPosted: Jan Wed 31, 2018 8:15 pm
Hey Bruce, I just finished recapping a 12S370... Complete chassis and in great shape... I will get you some pics tonight...
PostPosted: Jan Wed 31, 2018 10:22 pm
pixellany wrote:
Or..
+1
I picked up a CD with both Rider's and Beitmans and some extra info on it a couple years ago. Best money I ever spent, and it was cheap. The clarity is *so* much better than the online sources. Well worth getting.
Crawls Backward When Alarmed: Guitars, amps, vintage radios and more.
PostPosted: Feb Thu 01, 2018 4:27 am
Here's those pics... They are in no curtain order, hopefully they help...
PostPosted: Feb Thu 01, 2018 4:30 am
And the rest...
PostPosted: Feb Sat 24, 2018 2:51 am
Thanks sdradioman. Your pictures make me feel a lot better about this set. I just learned that this era Zenith came from the factory looking like it was wired by some7th grade kid. Yours does look better than mine so I've got a long battle yet.
Does anyone know of a good source for Zenith parts such as the IF cans and the switches for the push buttons?
Bruce Hagen
PS. Re the schematic I got a good 8 1/2 X 11 print that is now on 11X17 100 weight hard finish paper for $0.45 courtesy of Fed Ex. So much easier to read.
Bruce Hagen
PostPosted: Mar Wed 07, 2018 1:38 am
Still looking for the 1st and 3rd IF's. I'll take bad ones as long as the 2"x2"x3" look good.
Bruce
Bruce Hagen
PostPosted: Mar Fri 09, 2018 9:14 pm
Thanks to Paul I have the needed IF cans. And now another question. Where/what is the AC off/on switch. I do not have the cabinet and have a hanging toggle switch on a pair of wires. Somehow that does not quite fit the elegance of this set.
Thanks again,
Bruce Hagen
Bruce Hagen
PostPosted: Mar Sat 10, 2018 2:16 am
The on/off switch is locate on the right side of the dial, closest set of buttons to the dial.. It is a toggle sort of switch with a pair of pins sticking out of it, one on top, the other on bottom... When one is pushed, the other is kicked out... The switch is mounted to the shutter dial assembly itself with 2 screws...
PostPosted: Apr Thu 05, 2018 8:05 pm
Thanks SD. This is missing. Can anyone supply, can anyone post a photo of this part? I an add a switch to the volume control as it is on certain models but I'd like to do the original if possible.
And again thanks to all for your help in making this mess easier to save.
Bruce Hagen
Bruce Hagen
PostPosted: Apr Fri 06, 2018 11:49 pm
Sorry Bruce88 but I can add a pic as I already finished the radio and gave it back to the customer... I would imagine someone out there has one...
PostPosted: Apr Sat 21, 2018 9:57 pm
Did anyone ever notice that there is no B+ connection for the output stages? Well at least on the Rider's schematic there is no tap on the output transformer.
Bruce Hagen
Bruce Hagen
PostPosted: Apr Sun 22, 2018 2:37 pm
Noticed on those underchassis pictures that some of the sockets visible are missing terminal 1, which Zenith did because they were mad at RCA and didn't want to use the metal tubes, which use pin 1 for the metal shield and thus shielding. Nevertheless some metal tubes are visible being used topside in the pictures, with their pin sticking down into oblivion below, not doing the shielding that metal tubes could provide.
Reece
PostPosted: Apr Mon 23, 2018 10:07 pm
It was not only Zenith that did that. I got a nice little jolt back in the '40's on a couple of sets. Keeps one awake!.
Bruce
Bruce Hagen
Post New Topic Post Reply  [ 19 posts ]  Moderator: sofaslug
Users browsing this forum: No registered users and 14 guests
