It is currently Sep Wed 19, 2018 11:12 pm
 Post subject: Bipolar from two?
PostPosted: Mar Thu 08, 2018 11:10 pm
In this schematic, do the 2 caps connected back to back form a bipolar cap? When I look at this arrangement I see an imminent capacitor explosion. Why am I wrong? If they do indeed act as a bipolar cap, my next question would be did they not have bipolar caps in 1975? (That's the year the magazine was printed)
Invisible airwaves crackle with life
Bright antennae bristle with the energy - The Spirit of Radio
 Post subject: Re: Bipolar from two?
PostPosted: Mar Thu 08, 2018 11:12 pm
Yes, if you look at older bipolar caps, you can see it is a double ended can.
Scott.
PostPosted: Mar Thu 08, 2018 11:29 pm
https://electronics.stackexchange.com/q ... ectrolytic
They work fine as a non-polarized capacitor. Usually they are identical values.
Two 10 µF capacitor in series like this would yield one 5 µF non-polarized capacitor.
Curtis Eickerman
PostPosted: Mar Fri 09, 2018 4:39 am
The main reasons for using two capacitors is that it is a lot easier to find polarized capacitors and two of them will normally cost less than one non-polarized.
Some people will put diodes across the caps to be sure they are only slightly reversed but the two caps without diodes have normal life in my experience.
I have seen low voltage (less than 25 volts) AL electrolytics last 5 years even when installed in reverse polarity. Higher voltage caps usually fail in minutes to hours when reversed.
Reversed tantalum caps go bang almost immediately.
Users browsing this forum: rwhale and 4 guests
