| Author |
K4YDO
Post subject: Re: Finding your solder Posted: May Wed 30, 2012 1:29 pm |
Joined: Nov Mon 28, 2011 2:55 am Posts: 128 Location: Florence, SC 29506
Brian McAllister wrote: I have always considered breaking pieces off a roll of solder to be wasteful. You wind up with a bunch of little end pieces that cannot be used, and they sometimes wind up in awkward places. Seeing co-workers do this irritated me to no end and I am far from being a neat-freak. I can see a lot of you gentlemen work only on radios and have dedicated benches for the purpose. It seems I am always soldering at different locations and different types of items. Yesterday I was soldering on an electric powered honey extractor at a farm. Sure was nice to have the solder right at my iron !! Being able to find what is needed is worth the little bit of waste, which really isn't very much. I use needle nose pliers to hold the last little piece. To each his own. It works for me. Ed
| Top |
Nick D.
Post subject: Re: Finding your solder Posted: Jun Tue 05, 2012 8:19 am |
| Member |
Joined: Jun Wed 01, 2011 9:05 am Posts: 6730 Location: "Amish Country", PA
_________________ Majestic - Crosley - Zenith ~CONSOLE FREAK~ Philco - American Bosch - RCA
| Top |
gearhead222
Post subject: Re: Finding your solder Posted: Jun Sat 30, 2012 8:03 am |
Joined: Dec Sat 22, 2007 7:12 am Posts: 1952 Location: Great State of Texas!
I was lucky enough to buy a hollow pencil with solder in it at a local swap meet. To refill, I just wrap around 60-100 coils of solder around a small dowel and resinsert the solder back into the hollow plastic pencil with removable tip. Throw back in milk crate with rest of soldering tools and irons-problem solved!:)-Gearhead-PS-Here's a link to a similar solder dispenser. If you look up solder dispenser on Amazon, it should also come up: http://www.amazon.com/dp/B00386E1BC/ref ... B00386E1BCHere's another link: https://www.hobbymods.com/store/index.p ... -tube.html  -Gearhead
| Top |
Steve Johnson
Post subject: Re: Finding your solder Posted: Jun Sat 30, 2012 10:53 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4977 Location: Upstate NY, USA
gearhead222 wrote: I was lucky enough to buy a hollow pencil with solder in it at a local swap meet. To refill, I just wrap around 60-100 coils of solder around a small dowel and resinsert the solder back into the hollow plastic pencil with removable tip. Throw back in milk crate with rest of soldering tools and irons-problem solved!  -Gearhead Actually that's a great idea. I have a roll of really fine solder and it's always getting tangled on the roll. I don't usually use more than an inch or two at a time of the fine stuff. Using a fat hollow pen body should solve the problem.
_________________ Steve Johnson http://www.StevenJohnson.com Supreme Instruments 1926-1956
| Top |
markjd
Post subject: Re: Finding your solder Posted: Jul Sun 01, 2012 2:51 pm |
| Member |
Joined: Mar Tue 02, 2010 6:53 pm Posts: 297 Location: Virginia
An old pen converted into solder holder is a great idea. Should also be able to use a spring to keep the solder from sliding back into the pen body after it gets used.
| Top |
19&41
Post subject: Re: Finding your solder Posted: Jul Mon 02, 2012 1:05 am |
Joined: Apr Thu 21, 2011 2:00 am Posts: 189 Location: Georgia
I've been using a pen to hold solder for years now. You remove the clear tube and push the ink out with a bit of paper towel and finish with spray degreaser. Remove the very tip that holds the ball, and use degreaser on that portion. take the solder and run it through the clear tube with a couple inches to spare, then wind it on the tube so the coils stop where the plastic tip is. loosen the coils a bit on the clear tube and insert the whole thing in the pen housing. You pull the solder out the tip, it doesn't go back into the pen. A pen of this type holds about 13 ft. of solder.
| Attachments: |
| Top |
obbm
Post subject: Re: Finding your solder Posted: Jul Tue 03, 2012 12:38 pm |
Joined: Jan Mon 04, 2010 2:25 am Posts: 811 Location: Finger Lakes of NY
Thanks, 19&41 (?) What is that symbol?
This is a very clever, imaginative and useful idea. I tried it with 1/16" solder and it is a little tight in there, hard to pull out. The 1/32" solder in another one works great. I don't have any solder between 1/32" and 1/16".
The photo really helps understand this, thanks again,
Bill
| Top |
19&41
Post subject: Re: Finding your solder Posted: Jul Tue 03, 2012 2:15 pm |
It is a highway that runs south out of Atlanta. Keep an eye on your holder if someone comes by needing a pen. Lead is not what it's cracked up to be as a graphic medium!
| Top |
19&41
Post subject: Re: Finding your solder Posted: Jul Tue 03, 2012 10:25 pm |
And thanks for the kind words!
| Top |
Nick D.
Post subject: Re: Finding your solder Posted: Jul Thu 12, 2012 7:46 pm |
| Member |
obbm wrote: Thanks, 19&41 (?) What is that symbol? Never heard of an..... ampersand?
| Top |
obbm
Post subject: Re: Finding your solder Posted: Jul Thu 12, 2012 9:17 pm |
Of course, I first encountered the symbol and the word in 1948 (that's A.D.). I had not, however, seen an ampersand in that exact font, so I asked.
Bill
| Top |
fifties
Post subject: Re: Finding your solder Posted: Jul Fri 13, 2012 12:09 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8733 Location: SoCal, 91387
Nick D. wrote: obbm wrote: Thanks, 19&41 (?) What is that symbol? Never heard of an..... ampersand? &...The symbol for "and"
_________________ *******\\\\\\\\\******He Who Dies With The Most Radios Wins******/////////*******
| Top |
tribeam/omni
Post subject: Re: Finding your solder Posted: Aug Fri 17, 2012 4:52 pm |
Joined: Feb Sun 05, 2012 10:24 pm Posts: 42 Location: Toledo Ohio
Here is my method of using solder. These are centrifuge sample tubes with a screw on cap. Drilled a hole in the bottom, wrapped the solder around a dowel, slid the coil off of the dowel, passed the loose end back through the coil and through the hole in the end of the tube. Screwed the cap back on and that's it. When that twenty or so feet of solder was used up then do it again. These can be gotten from supply houses, or from a pathology lab in a hospital. Every one knows some who works in a hospital. I have used large syringes with the excess plunger cut-off. Also a long prescription bottle would work too.
| Attachments: |
| Top |
Chuck Schwark
Post subject: Re: Finding your solder Posted: Aug Fri 17, 2012 5:52 pm |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5867 Location: Evanston, IL
Great dispenser tip there TriBeam - thanks for posting it.
Chuck
_________________ Chuck Schwark,
The Philco Repair Bench
Schematic Photocopy Service
www.philcorepairbench.com
| Top |
Bruce Hagen
Post subject: Re: Finding your solder Posted: Aug Fri 17, 2012 7:44 pm |
Joined: Jun Thu 15, 2006 1:21 am Posts: 3794 Location: NE Ohio
I'm with Mike and Rickd. Have a roll on he bench and 4 or 5 roll on a shelf about 5' away. They rotate as needed.
_________________ Bruce
| Top |
Nick D.
Post subject: Re: Finding your solder Posted: Aug Sat 18, 2012 3:52 am |
| Member |
That solder dispenser idea is not a new one. Solder can be bought that way, in a similar tube, though there is a hole in the cap instead of the bottom of the container. http://www.amazon.com/Kester-Kwik-Draw- ... B00068IJI6
| Top |
Unusualdesigner
Post subject: Re: Finding your solder Posted: Aug Sat 18, 2012 9:42 pm |
| Member |
Joined: May Sun 08, 2011 10:45 pm Posts: 2913 Location: Southern Calif
Nick D. wrote: That solder dispenser idea is not a new one. Solder can be bought that way, in a similar tube, though there is a hole in the cap instead of the bottom of the container. That was available as far back as the 60s. At one time I used the glass "test tubes" that fine cigars come in for solder. No chance of an errant tip melting a hole in it  -although you didn't want to drop it, though...
_________________ It's easier to make a steam powered lobster trap than a lobster powered steam trap
| Top |
radiopicker
Post subject: Re: Finding your solder Posted: Aug Tue 21, 2012 5:39 pm |
| Member |
Joined: Aug Thu 18, 2011 4:48 am Posts: 2496 Location: Stamford, NY
| Top |
deltysdal
Post subject: Re: Finding your solder Posted: Aug Fri 24, 2012 2:33 am |
Joined: Nov Fri 28, 2008 4:45 pm Posts: 2233 Location: Near Fargo North Dakota USA
I cannot read this at all. Where are my glasses?
| Top |
Chuck Schwark
Post subject: Re: Finding your solder Posted: Aug Fri 24, 2012 10:02 pm |
| Moderator |
If you're browsing in Interneet Explorer, look in the bottom right corner of the browser window and you'll see a 100% next to a magnifying glass. Clilck on it to enlarge the text and screen for easier reading.
Chuck
| Top |
Who is online |
Users browsing this forum: No registered users and 1 guest |
