It is currently May Wed 24, 2017 7:00 am
 Post subject: Dual Rectifiers wired in Parallel???
PostPosted: Mar Mon 20, 2017 10:12 pm
I am playing around with some 866a rectifier tubes. I would like to run a pair of them in full wave mode. I am wondering if I can wire the 2.5V filaments in series with a 5V source (I don't have a 2.5V transformer).
Do you see any problems with doing this?
Collecting audio gear and radios because I couldn't afford to buy it when I should have.
 Post subject: Re: Dual Rectifiers wired in Parallel???
PostPosted: Mar Mon 20, 2017 11:53 pm
As long as your filament transformer can support 5V at 5 A I don't see any obvious problem. Of course I am not an expert on 866 Mercury Vapor Rectifiers. The filament transformer also needs to be rated for the HV insulation requirements as well.
Curtis Eickerman
PostPosted: Mar Wed 22, 2017 7:45 pm
I agree with Curtis in that your 5 volt winding should be rated for current and insulation. Also, be sure to use a choke input as opposed to a capacitor input filter. The 866's are excellent and will yield good regulation and life. I am FCC licensed and service a few small town AM stations that have 866's in some of their modulators, many of them have been in service for years.
I might add that most of them are fan cooled when in commercial service.
Post New Topic Post Reply  [ 3 posts ]  Moderator: Chuck Schwark
