It is currently Jul Thu 20, 2017 9:42 pm
 Post subject: Cleaning aged protective plastic from instrument panels
PostPosted: Apr Sun 16, 2017 8:44 pm
I needed to clean up my VTVM. The big problem was the old protective plastic has never been removed. I tried a heat gun, glue remover and a few other tricks. Nothing was working until I tried paint stripper. It worked to remove the plastic and did not harm the panel lettering. I could have done it without disassembly, but I wanted to a good job and get under the hardware. In hindsight, I think it was likely easier and faster this way. The entire process including disassembly took about an hour.
Here are before, during and after shots. Sorry about the order.
Ed
The more I know about women, the better I like my radios and TVs.
 Post subject: Re: Cleaning aged protective plastic from instrument panels
PostPosted: Apr Tue 18, 2017 2:24 pm
Nice Job! Which paint remover did you use?
Eddy
PostPosted: Apr Thu 20, 2017 5:16 pm
I used Stripeze, but I am confident that Kutzit would have worked the same. I buy whichever one is cheapest.
Ed
PostPosted: Apr Thu 20, 2017 6:03 pm
Naptha plus a soak overnight worked for my old 147A. Flakes were all loose or barely sticking, but the Naptha evaporated to about 40% of it's original volume. I've gotta try your method next time.....
Brian
USN Retired (Avionics)
PostPosted: Apr Fri 21, 2017 12:46 am
I was really paranoid about the panel lettering, so did it in segments and watched it closely. There was not even a hint that it might damage the letters, but I didn't leave it long enough to find out.
Ed
Post New Topic Post Reply  [ 5 posts ]  Moderator: Chuck Schwark
Users browsing this forum: WoodchuckTN and 4 guests
