If you don't have storage drawers here is how to make your own. I have some cardboard foldable boxes that are at least 40 years old. Some of them are not the best. I have access at times to a lot of really nice cardboard. So I took one of the old boxes I had a drew out a pattern on a piece of plywood. I drew the left side first then moved it over so the bottom would be 4 inches wide. I then drew the right side. I cut it out and now I lay it on a piece of cardboard to trace it on it. I usually put about ten pieces of cardboard together and then drill a couple of holes into each of the openings where the tabs go. I then put a bolt through that and put a washer and nut on the other end. Then I cut out along the line where I drew the pattern on. Then I unbolt and cut the openings of the tabs. I had all the cardboard I wanted, about 10 minutes of free time in the afternoon so I made a bunch. Here is a photo of the pattern and a few I made.
