Page 1 of 1
[ 13 posts ] |
| Author |
westcoastjohn
Post subject: A quicky tube socket repair Posted: Jan Thu 05, 2012 7:33 pm |
| Top |
codefox
Post subject: Re: A quicky tube socket repair Posted: Jan Thu 05, 2012 10:58 pm |
Yup, that's why I never throw anything away.
| Top |
Fred Scoles
Post subject: Re: A quicky tube socket repair Posted: Jan Thu 05, 2012 11:31 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1403 Location: Oswego, NY, USA
Along the same line of thought on tube sockets..whenever I have to replace an entire tube socket or a contact in a socket, it's not necessary to remove multiple wires from any of the old socket tabs. Simply dike/cut each of the old socket's tabs off near the old socket (or the one old tab if you're replacing just one contact). Then, after installing the new socket (or the new contact(s) into the old socket) into the panel, tag-solder the old intact tab (which still has all its components wires soldered to it) to the new tab. This saves work & frustration along with reducing the amount and duration of heat needing applied to heat sensitive components that are close to the socket. I've never had these tag-soldered joints come loose, as they aren't under any stress. I re-did an entire Simpson model 1000 tubetester panel in this way, and nothing has ever come loose on it.
These ideas were on ARF some years ago, but it may help to mention them again every few years.
| Top |
mescalero
Post subject: Re: A quicky tube socket repair Posted: Jan Sat 07, 2012 3:36 am |
Joined: Feb Thu 24, 2011 1:29 am Posts: 2816 Location: Dallas, TX - in the city but with bobcats and coyotes
I typically make considerable effort to replace the pins without removing the socket when I break one. It can usually be done. The "key" lies in finding how the pins are latched into the socket and undoing it without further destruction.
_________________ In a triode, no one can hear you screen.
| Top |
DocSlop
Post subject: Re: A quicky tube socket repair Posted: Jan Wed 25, 2012 5:08 am |
Joined: Jan Wed 19, 2011 5:28 pm Posts: 848 Location: mid-Michigan
Fred, I've just searched around the net for "tag soldering." Didn't find much. I'm not familiar with this technique. Could you explain it? Thx. -DS
| Top |
tubeAMP
Post subject: Re: A quicky tube socket repair Posted: Jan Wed 25, 2012 2:47 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2814 Location: Gainesville, Florida
coil is the way to go http://www.youtube.com/watch?v=OI9P01eYbjAI have made and installed many coils and works great. this guy solved a very important technique problem. the angle of the component and the tool. this is a revelation. so simple I never thought of it. makes it so much easier just this simple adjustment of the angle. unless you are making a museum piece coils is the way to go
_________________ CAUTION: Im no expert
| Top |
DocSlop
Post subject: Re: A quicky tube socket repair Posted: Jan Wed 25, 2012 4:03 pm |
tubeAMP wrote: coil is the way to go http://www.youtube.com/watch?v=OI9P01eYbjAI have made and installed many coils and works great. this guy solved a very important technique problem. the angle of the component and the tool. this is a revelation. so simple I never thought of it. makes it so much easier just this simple adjustment of the angle. unless you are making a museum piece coils is the way to go  I think I've heard that called a "squig." I've used them, but I've gone back to trying to get the old lead off unless it's a really impossible spot to reach. -DS
| Top |
FrankB
Post subject: Re: A quicky tube socket repair Posted: Jan Thu 26, 2012 7:39 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2169 Location: Olympia WA USA
Replacing just the broken pin is the way to go.
I have been doing that for over 40 years now. The difficult part is to find the exact pin for the socket you are working on. They made a lot of different types over the years.
When I got some old junker piece of gear- before sockets became hard to find- I would always pull out all the unsoldered tube socket pins and put them in a drawer. It was amazing how many unsoldered pins many of the TV sets had,especially on the damper & HV rect. sockets. My pin drawer has saved my goose many times over the years. ( Of course now I save every socket I find.)
I lost count of how many times I replaced the worn out pins ont he sockets in my tube testers, after they wouldn't re-tension any more. Sometimes you can't find the same type of mounting style socket they originally had.
Now if there was only a real easy way to replace a broken pin on a wafer socket or one that has a chunk of he bottom wafer broken out .....
_________________ FrankB WB7ELC Member: TCA "I know that all that is wrong with it is one little part".
| Top |
jgj6331
Post subject: Re: A quicky tube socket repair Posted: Jan Mon 30, 2012 3:16 pm |
| Member |
Joined: Nov Thu 08, 2007 4:37 pm Posts: 4386 Location: Central Georgia
DocSlop wrote: ........I've gone back to trying to get the old lead off unless it's a really impossible spot to reach. -DS I USED to do that too.... but after breaking off a couple of solder tabs and getting a couple of tube sockets and adjacent components way too hot - I'm a "lead coiler" now. Besides being less stressful (for both you and the radio) - it also makes it TONS easier to replace those components - if they ever need replacement - in the future........
_________________ JG Jackson
"Uva Uvam Videndo Varia Fit"
| Top |
dynadude
Post subject: Re: A quicky tube socket repair Posted: Feb Wed 01, 2012 11:00 pm |
| Member |
Joined: Aug Wed 26, 2009 5:38 am Posts: 3213 Location: Chapel Hill NC USA 27514
I have a tool I made especially for lead winding. I can't take credit for the idea though. Another member posted the idea here some time ago.
The idea is to use an Exacto knife handle and a short length of sturdy wire. I used the cut off lead from an old cap.
Bend the wire into tight "U" shape, leaving the opening in the U about the width of the average component lead. Place the wire into the slot of the knife handle, leaving the two ends facing out. Tighten the handle and then cut one side of the U to about 1/8" from the end of the clamp.
Now you can place the tip of most any lead between the two pieces of wire and turn the knife handle to coil the lead. Works like a charm.
_________________ Bryan at Spacekat Designs, Unique Musical Instruments
~Will work for parts~
| Top |
DocSlop
Post subject: Re: A quicky tube socket repair Posted: Feb Thu 02, 2012 4:11 am |
This telephone company "spooger" works well for making the coils.  -DS
| Top |
cwmoser
Post subject: Re: A quicky tube socket repair Posted: Feb Wed 08, 2012 1:53 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3363 Location: Advance, NC USA
dynadude wrote: I have a tool I made especially for lead winding. I can't take credit for the idea though. Another member posted the idea here some time ago.
Now you can place the tip of most any lead between the two pieces of wire and turn the knife handle to coil the lead. Works like a charm. Interesting tool. To make sure I understand, the 1/8" wire stubs purpose is to help with the winding the coil? Would a paper clip work as the "U" shaped wire? Think I'll make me one of these. Carl
| Top |
YRBNDR
Post subject: Re: A quicky tube socket repair Posted: Apr Wed 18, 2012 8:29 pm |
| New Member |
Joined: Apr Fri 13, 2012 6:06 pm Posts: 9 Location: San Angelo, TX
Having a lead tied to tightly to a socket usually results in breaking something, sometimes the pin of a socket, or lug off an IF can, or terminal off a pot.
After reading these posts, I wondered.......Lead bending, or twisting, coiling, seems very difficult.
Why not (as I do) just clip out the body only of the offending component, leaving the original leads straight and as long as possible. Take the new component, wind the lead around a jewellers screwdriver shaft, coiling it about 5 or 6 turns then snip off the excess. Then gently push the old lead into the new coils on the new component and overlay with solder.
| Top |
Users browsing this forum: No registered users and 2 guests |
