It is currently Jun Thu 20, 2013 2:45 am
 Post subject: How to clean these socket pins?
PostPosted: Sep Wed 05, 2012 3:21 am
How can I clean these socket pins? They seem to be silver, with most of them corroded.
 Post subject: Re: How to clean these socket pins?
PostPosted: Sep Wed 05, 2012 3:27 am
Hi,
What type tube goes into the socket? Does not look like one of the more common styles.
When I clean a socket I usually take the tube that fits it and spray some deoxit on the pins and then insert and remove the tube a few times. Then wipe up any excess deoxit off the socket and pins.
Silver contacts can look bad but still make good contact!
Corby
PostPosted: Sep Wed 05, 2012 5:32 am
Probably silver sulfide? I'd used Deoxit and a pipe cleaner to clean the socket.
Pete
A long journey always begins with the words, "I think I know a shortcut."
PostPosted: Sep Wed 05, 2012 6:02 am
Hi, I recently cleaned a set of socket pins and I used what Peter used.
I bought some pipe cleaners from a smoke shop in my area. The store had some soft ones and some coarse, i bought both, very cheap. I used them with alcohol and the gunk that came out on the cleaners was a lot.
Vin
PostPosted: Sep Thu 06, 2012 12:30 am
corbymite wrote:
Hi,
Corby
GU-50. I'll have to try to find some Deoxit.
PostPosted: Sep Fri 07, 2012 12:13 pm
DeOxit, as others have suggested.
One comment... DeOxit is not a general-purpose contact cleaner.
It's designed very specifically to clean oxidation from silver contacts.
For routine contact cleaning, as from grease or dirt, it's not very effective.
73 de Leigh W3NLB
http://www.AtwaterKent.info (Click on Grebe Stuff for Synchrophase info)
PostPosted: Sep Fri 07, 2012 12:31 pm
Leigh, welcome back.
Jim
"AC volts and DC volts and little lamps and lities..."
PostPosted: Sep Fri 07, 2012 12:49 pm
Indeed, welcome back, Leigh!
- Greg
WD8PHW
PostPosted: Sep Fri 07, 2012 12:59 pm
Thank you very much, Greg. I appreciate that.
Nice to be back.
73 de Leigh W3NLB
PostPosted: Sep Sun 09, 2012 3:31 am
Oh wow it is Leigh! Just love that atwaterkent.info
PostPosted: Sep Sun 09, 2012 4:10 am
Thanks very much. :D
73 de Leigh W3NLB
Users browsing this forum: AMChief, badwaxcaps, Ed Engelken, NumberMaj 1, Robert Buntzel and 7 guests
