It is currently May Sat 25, 2013 4:48 pm
Post New Topic Post Reply  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: AC Voltage Control for "Light Socket" Radio Sets
PostPosted: Mar Wed 21, 2012 11:50 pm
To dsen333v,
Thanks for sharing . Nice job on the line voltage control. Thanks for the update and testing the line voltage both ways. This has been a very interesting thread.
Bob
PostPosted: Mar Fri 23, 2012 1:56 am
Stan, straight line voltage is a HUGE concern with our antiques today. Fact is, most service is actually 125 volts rather than 120, and in some cases, it is 127. Mathematically, 125 volts is ~14% over-voltage of 110. That's a huge number for electronic equipment. You can extend this even farther by the fact that a '110 volt' radio will still fuction perfectly fine at 107, 105 and even 104 volts, as was the standard around the turn of the century.
At this maximum, you're looking at 19% potential over-voltage. Contrast that with the fact that the recommended window of voltage for 'fine' electrical things like radios and fans is +/-5% of the rated voltage. That would mean that the window for 110 volts would be ~105-115 volts.
PostPosted: Mar Tue 05, 2013 4:43 pm
I found this info in in a FTR book that I found from info provided in this thread.
viewtopic.php?f=2&t=217584
It provides some interesting info on reducing filament voltage to increase life span of tubes. I thought some members might find this interesting.
PostPosted: Mar Thu 07, 2013 2:03 am
The video and white paper links in the original posting for this topic are broken. Here are new links to copies that I have uploaded
Video
White Paper
Post New Topic Post Reply  [ 24 posts ]  Moderator: Chuck Schwark Go to page Previous  1, 2
