It is currently May Sat 25, 2013 12:14 pm
Post New Topic Post Reply  [ 1 post ]
 Post subject: Put a towel over it!
PostPosted: May Wed 09, 2012 4:44 am
Dunno if this has been mentioned before... but whenever you have
to dismantle something with a strong spring in it... it might be worthwhile
to first place it in something like a plastic tub or basin, and then put a
rag or towel over it. The heavier the spring, the heavier the towel.
This assumes you can open the device by feel, because you won't be
able to see what you're doing.
The basin contains small parts that might go flying, and the rag or towel
will help keep the spring from flying very far, if at all. Of course, your hands
might still be in some danger, depending on kind of spring it is.
You should still wear the safety glasses...
FWIW
Nelson
"Never get between electricity and where it wants to go." -Red Green
Post New Topic Post Reply  [ 1 post ]  Moderator: Chuck Schwark
