| Author |
K4YDO
Post subject: Finding your solder Posted: Mar Tue 06, 2012 2:36 pm |
Joined: Nov Mon 28, 2011 2:55 am Posts: 129 Location: Florence, SC 29506
If you can't always find your solder, here is a tip. Take a foot or so and wind it around the cord of your soldering iron. Your solder will always be there when you pick up your iron.
| Top |
Brian McAllister
Post subject: Re: Finding your solder Posted: Mar Wed 07, 2012 9:18 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2557 Location: Sarasota FL USA
I have always considered breaking pieces off a roll of solder to be wasteful. You wind up with a bunch of little end pieces that cannot be used, and they sometimes wind up in awkward places. Seeing co-workers do this irritated me to no end and I am far from being a neat-freak.
_________________ Brian McAllister Sarasota FL http://oldtech.net
| Top |
Nick D.
Post subject: Re: Finding your solder Posted: Mar Thu 08, 2012 4:08 am |
| Member |
Joined: Jun Wed 01, 2011 9:05 am Posts: 6736 Location: "Amish Country", PA
Brian McAllister wrote: I have always considered breaking pieces off a roll of solder to be wasteful. YES!+1
_________________ Majestic - Crosley - Zenith ~CONSOLE FREAK~ Philco - American Bosch - RCA
| Top |
fifties
Post subject: Re: Finding your solder Posted: Mar Thu 08, 2012 7:30 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8771 Location: SoCal, 91387
K4YDO wrote: If you can't always find your solder, here is a tip. Take a foot or so and wind it around the cord of your soldering iron. Your solder will always be there when you pick up your iron. Wouldn't it be easier to simply leave the roll near your soldering station? That's what I do.
_________________ *******\\\\\\\\\******He Who Dies With The Most Radios Wins******/////////*******
| Top |
wazz
Post subject: Re: Finding your solder Posted: Mar Fri 09, 2012 10:24 pm |
| Member |
Joined: Jun Wed 08, 2011 2:33 am Posts: 2062 Location: Ohio
Better keep it where you can find it ,but hidden, any day now the environmental police are gonna go looking for leaded solder. Buy all you can and stash it carefully. Already banned in European products. Like cops testing crack pipes, they may start testing your tips to see if they have any residue of 60/40 on them.
| Top |
fifties
Post subject: Re: Finding your solder Posted: Mar Fri 09, 2012 11:58 pm |
| Member |
They can take my soldering iron when they peel it from my cold, dead hands...
| Top |
Tubenut
Post subject: Re: Finding your solder Posted: Mar Tue 13, 2012 4:18 am |
Joined: Oct Sun 11, 2009 10:06 am Posts: 1441 Location: British Columbia
fifties wrote: They can take my soldering iron when they peel it from my cold, dead hands...  The question is, "will the iron still be hot?"
| Top |
codefox
Post subject: Re: Finding your solder Posted: Mar Wed 14, 2012 8:43 am |
If you can't find your solder, unplug the iron and take a nap (in that order, Ja?)
| Top |
Stan Ski
Post subject: Re: Finding your solder Posted: Mar Mon 19, 2012 12:00 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7027 Location: Clinton Twp. Mi.
On my work bench i have a sliding drawer to the right of my legs. Also have a reel type plug under the bench. I keep my soldering station and any other soldering stuff in the front of the drawer. When i am doing soldering i pull the door out part way out and plug it in and am ready to go. All my soldering equipment it right there by my right hand. Plus it eliminates all this stuff from being on top of the bench. Stan Ski
| Top |
JerryHawthorne
Post subject: Re: Finding your solder Posted: Mar Tue 20, 2012 6:05 am |
Joined: Feb Sun 24, 2008 4:21 am Posts: 2045 Location: Sedona, AZ
My roll is always on a special place on the wall until I need it. Then it comes down on my bench and is used. After using a while, I can never find out where I set it back down. Look a while and back to work. When done, it goes back to the only place I can find it, on the wall. Always a challenge when working. Jerry
_________________ A friend in need is a pest. Bill Slee ca 1972
| Top |
Mike Toon
Post subject: Re: Finding your solder Posted: Mar Sat 24, 2012 6:21 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5922 Location: Burbank CA
Buy several rolls. Sometimes cost isn't as important as time/sanity.
| Top |
Chuck Schwark
Post subject: Re: Finding your solder Posted: Mar Sun 25, 2012 4:28 pm |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5869 Location: Evanston, IL
If I have a bench that makes the spool of solder want to "creep away," I just chip off a small edge off one end to make a "flat tire" and that keeps it whe I last left it.
Chuck
_________________ Chuck Schwark,
The Philco Repair Bench
Schematic Photocopy Service
www.philcorepairbench.com
| Top |
BigBandsMan
Post subject: Re: Finding your solder Posted: Mar Mon 26, 2012 3:59 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6040 Location: Raleigh NC USA
Never have trouble keeping up with mine. I leave it on the spool, stand the spool on end, and twirl the solder off as I need it.  Larry
_________________ It don't make a go if it ain't got that GLOW!
| Top |
6gh8cowboy
Post subject: Re: Finding your solder Posted: Mar Wed 28, 2012 8:12 pm |
Joined: May Wed 11, 2011 6:24 pm Posts: 39 Location: Palm Beach County, Florida
I attached a short post on the back side of my solder stand (rat shack w a 20/ 40 watt switch). It's always there with the solder station and the added weight helps keep the stand in place. I pull the end to where I need and twist the spool to wind back when done. One stop shoping!
| Top |
rickd
Post subject: Re: Finding your solder Posted: Mar Fri 30, 2012 2:37 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1932 Location: seabeck,wa. usa
I'm with Mike. My "critical mass" seems to be 3 rolls. That way I can usually find one of them!
| Top |
Steve Johnson
Post subject: Re: Finding your solder Posted: May Sun 20, 2012 6:50 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4980 Location: Upstate NY, USA
K4YDO wrote: If you can't always find your solder, here is a tip. If you can't see the roll of solder on your bench I suggest you keep you work bench cleaner.
_________________ Steve Johnson http://www.StevenJohnson.com Supreme Instruments 1926-1956
| Top |
fifties
Post subject: Re: Finding your solder Posted: May Sun 20, 2012 10:02 pm |
| Member |
Steve Johnson wrote: K4YDO wrote: If you can't always find your solder, here is a tip. If you can't see the roll of solder on your bench I suggest you keep you work bench cleaner.  The picture on the right reminds me of some of the 1950's TV programs, where a married couple's bedroom scene consisted of two twin beds with a table and lamp in-between. Antiseptic and hardly realistic, lol.
| Top |
Stan Ski
Post subject: Re: Finding your solder Posted: May Sun 20, 2012 11:16 pm |
| Member |
Looks to me like the guy on the right is reaching for what appears to be a claw hammer. Not really a good tool to work on a radio with . So maybe the good is not so good Stan Ski
| Top |
Tubenut
Post subject: Re: Finding your solder Posted: May Mon 21, 2012 12:28 am |
HA HA, Stan beat me to it. That's a purdy scary work bench for someone to be working on a radio. So why is it that people scratch their head when confused? Was their a lot of itchy heads back then in the 50's? Maybe it was the hair grease.
| Top |
Steve Johnson
Post subject: Re: Finding your solder Posted: May Mon 21, 2012 2:12 am |
| Member |
Tubenut wrote: HA HA, Stan beat me to it. That's a purdy scary work bench for someone to be working on a radio. So why is it that people scratch their head when confused? Was their a lot of itchy heads back then in the 50's? Maybe it was the hair grease. With all the grease they used back then it could have been stuck in his hair.
| Top |
Users browsing this forum: No registered users and 1 guest |
