Page 1 of 1
[ 5 posts ] |
| Author |
N1KK
Post subject: Painting front radio panels Posted: Mar Mon 12, 2012 5:20 pm |
I have a NC-300 I would like to paint the front panel.
I heard of using vaseline and a tooth pick to cover the front panel lettering prevent spray paint from covering that area.
Wondering if anyone has done this and how well did it work.
Ken
| Top |
Unusualdesigner
Post subject: Re: Painting front radio panels Posted: Mar Thu 15, 2012 10:49 pm |
| Member |
Joined: May Sun 08, 2011 10:45 pm Posts: 2912 Location: Southern Calif
One problem you might have with it is that it's rather hard to keep Vaseline from migrating to where you don't want it. One stray bit and a botched paint job.
I would experiment with clear packing tape (makes it easier to see where you're applying it) and the intended paint to see if it won't mess with the adhesive. You could even precut pieces by sticking it on glass.
Of course, YMMV.
_________________ It's easier to make a steam powered lobster trap than a lobster powered steam trap
| Top |
wa8dof
Post subject: Re: Painting front radio panels Posted: Mar Fri 16, 2012 12:38 am |
| Member |
Joined: Dec Tue 28, 2010 6:28 pm Posts: 191 Location: Marquette MI
I have a friend that has good luck with this process using rubber cement. I have not tried it but he has done some fine work with it.
I would certainly practice on something expendable first!
_________________ WA8DOF@YAHOO.COM
| Top |
BlaineA
Post subject: Re: Painting front radio panels Posted: Mar Sat 17, 2012 2:37 am |
Joined: Nov Sun 02, 2008 8:06 pm Posts: 151 Location: Fredericton NB Canada
There is a product called friskit . Painters use these to mask areas that they do not want to paint to stick. Michale's has it or any art supply stores.
_________________ Fessenden gave radio a voice
| Top |
jgj6331
Post subject: Re: Painting front radio panels Posted: Mar Sat 17, 2012 3:27 am |
| Member |
Joined: Nov Thu 08, 2007 4:37 pm Posts: 4386 Location: Central Georgia
On raised (silk-screened) lettering, I have been successful preserving it by using a slow-drying flat enamel and then carefully removing the paint over the letters (before it dries) with mineral spirits and a lint-free rag (like a piece of bed sheet). Then, once everthing has dried sufficiently, I then give it a couple of semi-gloss clearcoats and adjust the gloss as necessary with 4-0 steel wool. The few times I've tried this - it worked great.
_________________ JG Jackson
"Uva Uvam Videndo Varia Fit"
| Top |
Users browsing this forum: No registered users and 2 guests |
