gearhead222 wrote:
I am crediting this to Curt Reed (may he RIP) for this great tip! Amazing how many people don't know this! I just enlightened my best tube supplier and he's pretty sharp! I'm sure that this has been covered before, but it never hurts to bring it up again.
When removing a Loctal tube from it's socket, look for the bump at the base of the tube. Then go 180 degrees AROUND the metal tube-this is where you start rocking. In effect, you're pushing force is directed at the bump on the other side of the base. DO NOT grab the glass envelope-just the base! GENTLY rock back and forth while GENTLY lifting and the tube will quickly and easily come out (most of the time). You'll never go back to your old methods once you discover the correct way to remove Loctal tubes. Thanx again Curt!:)-Gearhead222
What!, the miniature crowbar I have been using is wrong?!?!?
Thanks for the reminder!
