It is currently Sep Tue 18, 2018 6:17 pm
 Post subject: Scrounge sources for HV Electrolytic Caps 40uf - 150uf
PostPosted: Oct Tue 02, 2012 12:57 am
If you're looking for a scrounge source for Electrolytic Capacitors of 400v+ look inside dead LCD displays. The internal HV power supplies contain 1 HV capacitor. Sizes are usually one of the following: 40uf, 68uf, 82uf, 100uf, 120uf, or 150uf. If the display was made between 1997 and 2007 then the other electrolytic capacitors (220uf - 3300uf) are probably no good (https://en.wikipedia.org/wiki/Capacitor_plague).
There will be some blue drop HV caps as well.
 Post subject: Re: Scrounge sources for HV Electrolytic Caps 40uf - 150uf
PostPosted: Oct Thu 25, 2012 8:59 pm
Old PC power supplies will yield two 470 or 680 uF caps, but at only 200 volts working. Voltage is OK for AA5 B+ filters (not AC radios) but the capacitance is far too large to hang directly off the rectifier cathode. However, if you put a series 100 ohm 5 watt WW in there to cut the ripple current they work very well.
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Oct Wed 31, 2012 5:04 pm
I am amazed that you see old can type lytics for sale on ebay, probably 40+ years old, and people are buying them for alot of money sometimes. They are often NOS in the box but usually untested.
PostPosted: Nov Mon 05, 2012 11:24 am
Don't know about tested.... More likely without being reformed first, there is a strong possibility that they have depolarised (lost form). I did see possibly 2003 some NOS 1958 electrolytic caps., in a tank PSU, self destruct, dramatically (would have been as good as the cannon) when they hooked the PSU up & fired up in the tank (24V Lead acids).
Was it not F.T Barnum that said to the effect "that there was one born every day"
Marc
PostPosted: Dec Sun 16, 2012 10:31 pm
I'll admit to using old NOS electrolytics on occasion but I carefully reform them on a Sprague TO-6A tester. Then, if they still draw more than 0.5 mA at working voltage, I toss them. I always replace old, as-found, used electros - not worth the risk even if they reform... I'm restoring for the next 50 years, so they won't last 120 years!
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Dec Sun 16, 2012 11:26 pm
Marc
We need to bring you up to speed on your Americanisms, lol.
It was P.T. Barnum who said, "there's a sucker born every minute"... :wink:
And with E-Caps being so cheap, why gamble on re-forming, when it's even odds that it will fail anyway? If it's in a circuit with an unobtanium transformer, how you say, penny wise and... :shock:
PostPosted: Dec Mon 17, 2012 1:43 pm
If I HAVE to reform old HV caps, (like when I want to try to fire up some old tube electrojunk unit, and see if it MIGHT work) I start by re-polarizing the caps by first hooking up a AA, C, or D battery in a batt holder, and clip lead in, (+>+, ->-) and a voltmeter on it... I check the voltmeter to see if the cap's polarity is not confused, and leave it on for a few days to properly polarize it, and I heard that this will start to "heal" the oxide layer in the cap... Then, reform caps very slowly...
This seems to help my high success rate of first power-up... If I like unit, then I will recap...
(RISE, MONSTER, RISE, HA,HA,HA!!!!!!!!!!!!!!!!! It's the mad scientist in me!!!!!!!!)
Steve K
PostPosted: Aug Sun 17, 2014 3:04 am
Dead laptop power supplies or any other type of external switching power supply may have a 100uf 400v ecap in them.
PostPosted: Aug Sun 17, 2014 4:37 am
As it was previously mentioned trying to salvage used or NOS electrolytics is a waste of time. At todays prices there is no reason to use old or used components.
PostPosted: Aug Sun 17, 2014 6:26 am
I keep old parts for test and klooge purposes. New ones for permanent repairs.
The purpose of a hobby is to waste time in an enjoyable manner.
RRM
PostPosted: Aug Mon 18, 2014 6:44 pm
If one does not immediately have a new capacitor and one has a cap that one salvaged from another piece of equipment, one could continue working on a piece of equipment while one waits on parts to arrive. One could also fix a piece of equipment in an emergency.
PostPosted: Aug Tue 19, 2014 3:57 am
Most definitely.
They can also be good for when you are not sure what capacitor you may need for a circuit as you will more than likely have several values at different voltages that you can try.
Post New Topic Post Reply  [ 12 posts ]  Moderator: Chuck Schwark
Users browsing this forum: MAG and 1 guest
