Author |
pixellany
Post subject: labels on polyethylene parts drawers Posted: Dec Tue 17, 2013 3:40 pm |
Member |
Joined: Jul Mon 26, 2010 8:30 pm Posts: 21868 Location: Annapolis, MD
I was not able to find a label that would stay attached to polyethylene. After trying a few things, I stumbled on a solution:
Clean the surface and then spray with 3M #77 spray adhesive---for some reason, this stuff seems to REALLY like Polyethylene.....) Let dry 5 minutes or so Put on the label (I'm using the Avery "permanent" labels, but I'll bet that others will work)
I'll update this in a month or so---meanwhile, fingers crossed
_________________ -Mark http://pixellany.com
Top |
telegrapher
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Wed 18, 2013 6:19 am |
Member |
Joined: Feb Thu 24, 2011 3:13 pm Posts: 791 Location: Ironwood, MI
Pixellany...I'll be watching your progress and hope it goes well.
Two years ago I sucked it up and decided to organize all of my caps and resistors. I bought eight 48-drawer utility cabinets. The sorting wasn't actually all that bad of a job but...
KIDS----DON'T TRY THIS AT HOME------
I used a Dymo labelmaker to create every label. Now, every single day I have to press at least 5 to 10 of these stupid labels down flat because they're curling away from the plastic drawers. What a magnificent waste of time those labels were! Making those %&#@ labels was far more tedious than sorting the parts.
So I'll be watching with interest so I can throw these labels (and my Dymo labelmaker) away.
Top |
Bruce Hagen
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Wed 18, 2013 8:17 pm |
Joined: Jun Thu 15, 2006 1:21 am Posts: 4683 Location: NE Ohio
Goodyear Pliobond
_________________ Bruce
Top |
Chas
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Wed 18, 2013 11:00 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 12021 Location: S. Dartmouth MA 02748-1225 USA
Bruce Hagen wrote: Goodyear Pliobond +1 one of the few good for most things glue.
Top |
Frank in Selkirk
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Thu 19, 2013 1:54 am |
Joined: Jan Mon 24, 2011 6:03 pm Posts: 316 Location: Selkirk,MB,Canada
I also had the same problem keeping Dymo labels on.Finally I got fed up with continually reattaching them.I stuck transparent Scotch tape right over the labels,over lapping considerably.They're now staying put.
Top |
threeneurons
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Thu 19, 2013 3:22 am |
Member |
Joined: Jul Sun 17, 2011 1:11 am Posts: 4332 Location: Los Angeles
Brother P-Touch labels. They don't come off. Also regular paper Avery labels. Those you can stick in your printer and edit the label text in Word. Both of these seem to stick. Haven't used a Dymo label maker since high school.
_________________ Life is like a roll of toilet paper - The closer you get the end, the faster it goes - A.E. Neuman
Top |
Chuck Schwark
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Thu 19, 2013 3:55 am |
Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6075 Location: Evanston, IL
I use a black, fine-point Sharpie. Indelible, permanent, and readable from across the shop.
Chuck
_________________ Chuck Schwark,
The Philco Repair Bench
Schematic Photocopy Service
www.philcorepairbench.com
Top |
pixellany
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Thu 19, 2013 5:43 am |
Member |
Chuck Schwark wrote: I use a black, fine-point Sharpie. Indelible, permanent, and readable from across the shop.
Chuck If I do that on polyethylene, it rubs right off. On acrylic, it's better, but I can still rub it off. But then---on acrylic, the Avery labels stay on better....
Top |
edison64
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Sat 21, 2013 6:35 pm |
Member |
Joined: Mar Wed 04, 2009 4:24 am Posts: 672 Location: La Porte Walkerton NW Indiana
threeneurons wrote: Brother P-Touch labels. They don't come off. Also regular paper Avery labels. Those you can stick in your printer and edit the label text in Word. Both of these seem to stick. Haven't used a Dymo label maker since high school. Plus one to this idea I went to Lowes and bought the generic P Touch label ur that they sell I bought a couple cassettes of black on clear And black on white They seem to be sticking just fine and its been about 6 months now. the Avery labels also work quite well.
Top |
pixellany
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Sat 21, 2013 7:02 pm |
Member |
Is everyone talking about Polyethylene?
i have found NO labels that will stay stuck to this......??? Acrylic, yes.....
Top |
edison64
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Sat 21, 2013 7:46 pm |
Member |
I don't know about everyone else. but in my case I am talking about the cheap translucent flexible plastic drawers I basically purchased all my storage units at Menards.
Top |
Pbpix
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Sat 21, 2013 7:50 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 22389 Location: Haledon, NJ, usa
my stick-on paper labels fell off too... so now I use Scotch tape over them... that does it.
_________________ To be a man, Be a non-conformist, Nothing's sacred as the integrity of your own mind. -Emerson
Top |
threeneurons
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Sat 21, 2013 7:56 pm |
Member |
The only things I know are polyethylene are bottles water and drinks come in. I suspect you're talking about the flexible plastic drawers that a bit milky in color. If so, both the avery labels an p-touch label stick. Sharpy ink rubs off, but ok for temporary marking.
Top |
Stan Ski
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Sun 22, 2013 1:16 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 10085 Location: Clinton Twp. Mi.
How about using a can of clear coat over the label ? Or would this mess up the plastic? Stan Ski
Top |
telegrapher
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Sun 22, 2013 3:25 pm |
Member |
Chas wrote: Bruce Hagen wrote: Goodyear Pliobond +1 one of the few good for most things glue. +1/2 for Pliobond (but it's no longer made by Goodyear...company called Ruscoe manufactures it now). It's good but it's also CONTACT CEMENT. So for maximum adhesion you're supposed to paint on each piece, wait, then attach; kind of a pain. But it's good stuff if you have the patience and wouldn't mind the mess. For me attaching several hundred labels, uh-uh. It's also very toxic and illegal to sell or use in a number of states.
Top |
Bill njb
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Thu 26, 2013 5:42 am |
Joined: Oct Tue 06, 2009 8:41 pm Posts: 1018 Location: Ceres, CA 95307
I put satin transparent scotch tape on the drawers and write on the tape with a sharpie pen. They haven't fallen off or smudged. Bill
Top |
pixellany
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Thu 26, 2013 2:22 pm |
Member |
threeneurons wrote: The only things I know are polyethylene are bottles water and drinks come in. I suspect you're talking about the flexible plastic drawers that a bit milky in color. If so, both the avery labels an p-touch label stick. Sharpy ink rubs off, but ok for temporary marking. They look and feel like polyethylene, therefore I assumed.......... Specifically, these are the drawer sets from Akro Mills----sold everywhere. Drawers are flexible---unlike the acrylic ones---and no Avery label will stay stuck. So far, the method I reported is holding up---no sign of anything coming loose.
Top |
threeneurons
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Fri 27, 2013 7:53 am |
Member |
Okay, so we are comparing apples and oranges:  Pix's bins are probably #1, 2, or 4. The flexible plastic parts bins, I have, are #5, which is polypropylene. Acrylic, though not listed, is hard. That's an easy one to distinguish. Only my really old bins used acrylic. So, either have some 3M 77 spray on hand, or get bins that have the #5 on them.
Top |
pixellany
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Fri 27, 2013 12:06 pm |
Member |
wow--real data!!
Mine have no markings to indicate what they are....
Top |
19&41
Post subject: Re: labels on polyethylene parts drawers Posted: Dec Fri 27, 2013 12:11 pm |
Member |
Joined: Apr Thu 21, 2011 2:00 am Posts: 3221 Location: Georgia, 30236
Sharpie ink "takes" better on polyethylene and polypropylene if you wipe off the surface to be marked with a paper towel or tissue wetted with lighter fluid. Sharpies are the only thing that seems to stay on such surfaces. Tape will cover it, but sometimes the adhesive will cause the markings to bleed into it, blurring the label. Mylar tape makes a good label for such surfaces too.
Top |
Users browsing this forum: No registered users and 2 guests |
