It is currently Feb Thu 21, 2019 6:58 pm
 Post subject: Shielded Twin Banana to BNC Adapter
PostPosted: Aug Tue 05, 2014 5:44 am
I wanted a shielded adapter to accept a 3/4" spaced twin-banana plug and connect to a BNC connector.
The key is a coax UHF-Female to BNC-Male adapter. To this is added a hand-made mounting plate and a grounding banana socket bushing; (solid metal, no insulator at all).
The first photo is the professional GR connector version, but not fully shielded at the binding posts:
File comment: GR adapter
The banana plug fits the center female contact of the UHF connector very nicely.
Here is what I built, with a dual-banana plug shown for scale:
File comment: Assembled Adapter and Plug
In the exploded view it is shown that the mounting plate has a large hole drilled and filed for the UHF connector, and has the grounding banana bushing spaced on 0.75 inch centers, a pair of mounting nuts for the UHF-Female secures the plate. If you don't have a bushing like that in the junkbox, the type of banana socket that used nuts and plastic shoulder washers for insulation could be used without its insulators.
File comment: Exploded view
Here the banana grounding bushing is seen sideways on the mounting plate (just a small scrap of aluminum sheet).
Ex: Same job, same building, same phone #; 4 Corp's: RCA, GE, Martin, Lockheed-Martin: 48 years
 Post subject: Re: Shielded Twin Banana to BNC Adapter
PostPosted: Aug Tue 05, 2014 1:26 pm
The GR adaptor in your first photo (apparently a Type 874-Q2) is designed to mate with a Type 874-ND to provide a well-shielded connection:
Post New Topic Post Reply  [ 2 posts ]  Moderator: Chuck Schwark
