It is currently Feb Mon 19, 2018 12:36 pm
 Post subject: Zenith Band Switch Linkage
PostPosted: Feb Sun 08, 2015 9:41 pm
If you are a purist, move along to another topic.
The pot metal in Zenith band switch linkages is a weak spot as I found out in my 8S661. Here is a photo of my fix. The L shaped piece was taken from an element mount on a trashed roof top TV antenna, bent to fit, attached to the switch shaft with a hose clamp, and then pop riveted to the linkage arm.
I could have looked for a replacement piece but pot metal just continues to deteriorate and I wanted to fix it once and only once.
Dick
The trouble with trouble is that it usually starts out like fun.
 Post subject: Re: Zenith Band Switch Linkage
PostPosted: Feb Wed 11, 2015 6:15 am
Great and easy solution.
Not OEM, but unless one can do the castings, that should last many years.
Great idea!
FrankB
WB7ELC
Member: TCA & Steel Soldiers.
" Break down the wall"
PostPosted: Feb Sat 14, 2015 5:02 pm
Nothing wrong with an honest repair. You can also silver solder or braze the new arm to a small sleeve made from copper tubing with an ID suitable to slip over the broken pot metal part, and epoxy the two pieces together.
Post New Topic Post Reply  [ 3 posts ]  Moderator: Chuck Schwark
