It is currently Oct Mon 15, 2018 7:55 pm
 Post subject: Reading Faded Tube Lettering
PostPosted: Aug Wed 10, 2016 5:21 pm
Haven't tried this yet...
READING FADED TUBE LETTERING
When the type numbers of radio and TV tubes are obliterated to the point where they can't be read, try viewing them through the tube from the opposite side in a strong light. The numbers and letters are usually legible when observed in this manner provided that the interior of the tube isn't coated. -Peter Barna, Wilmington, Calif.
(Popular Electronics - October 1959)
 Post subject: Re: Reading Faded Tube Lettering
PostPosted: Aug Wed 10, 2016 9:05 pm
Try using a single white LED flashlight in a darkened room. I have seen this work when breathing (fogging), ammonia and other techniques have failed.
Having a knowledge of what the tube internals normally look like helps.
Chas
PostPosted: Aug Wed 10, 2016 10:59 pm
There is often some lighting condition that will work...I had good luck with a light going across the glass surface ("grazing incidence" in optical talk). But....guessing and testing is sometimes faster than finding the perfect lighting.
-Mark http://pixellany.com
PostPosted: Aug Sat 13, 2016 9:04 pm
I know this sounds a bit odd, but sometimes I have had success putting the tube in the refrigerator for a couple of hours. Then I pull it out and sometimes it is legible straight off or sometimes I use a light as Pix and Chas mentioned after taking it out of the fridge.
Tony
PostPosted: Aug Wed 17, 2016 2:16 am
I use a magnifiying glass to examine the letters and numbers after applying any of the common techniques such as mentioned, since often part of a character is worn away. Sometimes just the outline is partially visible.
:idea: What about using polarized light or polarizing filters to view the label? Anyone tried that?
-BMS-
PostPosted: Aug Wed 17, 2016 4:11 am
[quote="BlewMagikSmoak" :idea: What about using polarized light or polarizing filters to view the label? Anyone tried that? -BMS-[/quote]
Try it... Also coherent light from pocket laser. Surely one has seen the specular effect from a laser beam striking the edge of a object, dust on the wall, etc. The edge of faded lettering may do the same thus enhancing the edge of the markings.
PostPosted: Sep Sat 17, 2016 10:14 am
Tried the laser. Oddly, I could make out letters / numbers and outlines of them on the inside of the glass not much from the outside. Concave vs. convex effects?
PostPosted: Feb Mon 13, 2017 7:02 pm
Another tip on tube lettering below. Ammonia?
PostPosted: Apr Wed 19, 2017 8:55 pm
One time I used superglue. Put tube in gallon zip lock bag. Carefully set on bench and put a few drops of superglue in the bag with the tube. Don't get any on the tube. Leave for several hours. Hopefully the fumes will make numbers visible!
PostPosted: Apr Wed 26, 2017 7:13 am
"Hopefully the fumes will make numbers visible!", along with any fingerprints left behind....a standard method used in crime labs.
PostPosted: May Mon 08, 2017 9:22 pm
HI:
I HAVE USED MY BREATH ON THE NUMBER AREA.
I ALSO HAVE A MAGNIFIER WITH A ULTRA VIOLET LEDLIGHT.THIS MUST BE DONE IN A DARK ROOM.
WALTER-W2WIQ
PostPosted: Oct Fri 13, 2017 7:11 am
the best method I have found is run your finger on an oily part of your face, brush the glass with it in several directions where the number should be (above the base key is where ). Look at it under your florescent magnifier lamp. Works 90% of the time ! Clean the glass first if real dirty.
Mark Oppat
PostPosted: Oct Fri 13, 2017 4:30 pm
Weather and planetary orientation obliging, I have often simply needed to take my impossible to read tubes out into the bright sunlight and catch just the right glancing angle, or grazing incident as it were, of light. Of course here in the PNW, the "obliging" weather is often a bit elusive in the winter months.
Oh yes. That and my strongest pair of reading glasses... :shock:
- Scott
Post New Topic Post Reply  [ 13 posts ]  Moderator: Chuck Schwark
Users browsing this forum: HRansier and 2 guests
