It is currently Feb Thu 22, 2018 10:04 am
 Post subject: Save Those Dead Tube Pins.
PostPosted: Dec Thu 01, 2016 3:34 am
If you have any dead octal tubes break them up and save the old socket pins in the base. It's easy to de-solder the wires in them to get a clean hollow pin. I've found a use for three already. I'm working on a Silvertone R1181 and the outside antenna wire was missing from the terminal on the back cover that connects it to the radio. It plugged into a socket on the chassis. One of those pins fit perfectly so I made up a new wire.
The second use; I used them to make a removable power connection on a GE 511 clock radio. The AC cord goes directly to the clock and then to the radio. I made the wires going to the radio part so that I could unplug it from the clock without removing the clock also. I used the female socket for the pins from an old computer four pin connector. It worked out very well.
"I know nothing about everything" Sgt. Schultz.
 Post subject: Re: Save Those Dead Tube Pins.
PostPosted: Dec Thu 01, 2016 3:37 am
See my thread entitled "save everything". ( but add: "until you can't get into your shop"....;) )
Seriously...good tip
-Mark http://pixellany.com
PostPosted: Dec Wed 07, 2016 4:06 am
3) Those octal pins are also exactly the same size that fits the oddball Hickok test jacks found on some of their older tube testers and signal generators.
Cheers,
Grid2
Post New Topic Post Reply  [ 3 posts ]  Moderator: Chuck Schwark
