It is currently Feb Thu 22, 2018 7:55 am
 Post subject: Gluing cabinets before stripping
PostPosted: Mar Fri 10, 2017 12:05 am
I have found that if I glue the parts on a wood cabinet that need to be glued, I do it before I strip the cabinet. If any glue gets on some of the finish it won't soak into the wood grain.
It will sit on the old lacquer, which will be stripped off later
In the past I have stripped first and then glued, but unless you are very careful the glue will get on the wood where you don't want it.
Dan in Calgary.
 Post subject: Re: Gluing cabinets before stripping
PostPosted: Sep Wed 27, 2017 2:54 pm
+1 --- I can agree with this advice completely.
Robert
PostPosted: Oct Sun 01, 2017 1:50 am
+2 here. It is always best, whether working on an antique radio or any other antique furniture, to perform all wood repairs prior to stripping the finish.
Several reasons for this: First and most importantly, as previously mentioned, to prevent glue from getting onto a newly-stripped surface. But also, many times during wood cabinet repairs some sanding will be required. Best to perform any needed sanding prior to stripping; although sanding will expose bare wood the stripping process will "smear" some of the original finish back onto the sanded bare surfaces, making it much easier to later obtain a uniform color.
Poston
PostPosted: Dec Thu 28, 2017 3:46 pm
Yes! I learned this by trial-and-error...and mostly I use a animal-based Wood glue - water soluble for easier clean up.
Want-Crosley Playboy 124 cabinet any cond
Stromberg 1A chassis
Big Hallicraftrz Spkr
KD2AZI
Post New Topic Post Reply  [ 4 posts ]  Moderator: Chuck Schwark
Users browsing this forum: hunter2115 and 3 guests
