It is currently Feb Wed 20, 2019 8:26 pm
 Post subject: Advice for working with steel chassis
PostPosted: Feb Sun 05, 2017 4:18 pm
Greeting gang, I have an old dynamotor chassis I want to build a power supply on for an ARC 5 transmitter , I don't have to do too much cutting ,but there is a opening I need to enlarge about an inch or so to accommodate the wires for the power transformer . Any thoughts on proper tools ? I don't have any cutting wheels yet ,but that's the direction I'm going and or filing . :D Will chassis punches work on steel if it isn't too heavy gauge ?
Thank you
 Post subject: Re: Advice for working with steel chassis
PostPosted: Feb Sun 05, 2017 4:32 pm
Yes, unless claimed not for steel... 1/8" mild steel is about max, lubricate well both cutting surfaces and the threads.
"Gandhi"
PostPosted: Feb Thu 16, 2017 3:15 am
They make metal hole saws. That metal is likely too thick for a nibbler, IIRC. Sometimes a cone reamer will work well. They make some large ones for pipe up to 2" that I have seen.
Do NOT use a fly cutter with a hand drill. (:oops: ).
I have used an air die grinder also.
Often, your local full service welding or machine shop has a punch capability.
(Talk to them. You might be able to get it done for a 6 pk. left by their back door.) :wink:
FrankB
WB7ELC
"The average family has 2.5 children. Where is the other .5 child?"
PostPosted: Feb Thu 16, 2017 3:49 am
Might try a Dremel using the thicker cut-off wheel.
PostPosted: Feb Thu 16, 2017 3:58 pm
step drill
PostPosted: Feb Thu 16, 2017 4:03 pm
Flinx wrote:
step drill
Yep! Those do a good job, use plenty of lube too. Some step bits are in metric others fraction. They can grab the work so use clamps.
"Gandhi"
PostPosted: Mar Fri 10, 2017 4:42 am
+1 on the Greenlee chassis punches and the old time pipe reamer. I have an old vintage pipe reamer that will ream a hole from 1/4" up to 4 inches.
PostPosted: Mar Fri 10, 2017 7:38 pm
Allow for extra room to add a grommet to protect the wires.
PostPosted: Sep Wed 20, 2017 12:48 pm
Chas wrote:
Flinx wrote:
step drill
And work gloves! Ask me how I know to do this...
KN4GGM
"You should not ask questions without knowledge." Deming
Post New Topic Post Reply  [ 9 posts ]  Moderator: Chuck Schwark
Users browsing this forum: WoodchuckTN and 5 guests
