It is currently Oct Fri 19, 2018 1:58 pm
 Post subject: Stag covering removal trick.
PostPosted: Aug Sun 13, 2017 6:55 pm
I looked here for this trick, but didn't see anything about stag removal. I decided to replace the stag covering on a TO-600 that’s in bad shape and has been sitting here for a while. I went through all the recovering documents I could fine.
They just say to pull it off with your fingers, putty knife, or credit card and then sand all the black specs off with a sander. So I started pulling some of the stag off, but some of it wanted to tear or wouldn’t come off at all. I found that using a sponge soaked in warm to hot water loosened the glue and I could lift it up easier. Let it soak for 10 to 15 minutes. I also noticed that a soaked face cloth worked better because I could cover more area. Re-soaking the cloth half way through seems to speed things up.
I now had the wood with glue and stag pieces on it. Instead of waiting for it to dry so I could sand it smooth, I found that I could remove the black specs with a putty knife if it was damp. One of those cheep putty knives that has a beveled edge. In about an hour, I had whole cabinet cleaned and only minimal sanding needed. They must have used better glue when gluing the wood pieces together, because it’s been over a week now and the frame is still holding together.
Now some light sanding and I'm ready for new Tolex.
Hope this helps someone in the future.
Freeman.
Post New Topic Post Reply  [ 1 post ]  Moderator: Chuck Schwark
