It is currently Sep Thu 20, 2018 4:12 pm
Post New Topic Post Reply  [ 39 posts ]  Go to page 1, 2  Next
 Post subject: Atwater Kent Model 3 Breadboard
PostPosted: Jun Thu 07, 2018 8:37 pm
This looks like an AK Model 3, Is it:
https://www.ebay.com/itm/Atwater-kent-b ... SwCshbF91s
GL,
Terry
 Post subject: Re: Atwater Kent Model 3 Breadboard
PostPosted: Jun Fri 08, 2018 1:09 am
Yes, that's a 3 and it looks to be in original condition. The wires below may have been resoldered.
Recently sold 3: https://www.ebay.com/itm/VINTAGE-1923-O ... 7675.l2557
Michael Feldt
www.indianaradios.com
PostPosted: Jun Sun 10, 2018 1:57 am
Am I mistaken, or are the brass screws missing from the TA island?
PostPosted: Jun Sun 10, 2018 4:42 am
Yeah, they do seem to be missing. That's not a good sign.
Michael Feldt
PostPosted: Jun Sun 10, 2018 4:45 am
There are components in the bottom of the TA, covered with tar to protect from moisture.
If the TA cover is lifted without support it can break the wires to those parts.
Missing screws could allow that to happen in transit. Not good.
PostPosted: Jun Sun 10, 2018 11:02 pm
You no longer have to wonder about the interior of the TA unit. The transformers are gone.
He added this comment:
I was following some posts on the Radio forum and they pointed out that there are screws missing on the island and sure enough they were right I've got a box of 5/32 brass screws so thats not a problem it looks like at some point a previous owner wanted to make it work and got as far as cleaning out the can. I had one more picture I could post so you can see for yourself. I want whoever buys this to get exactly what they're expecting. I'll do my part and pack it right.
Jimmy
http://www.atwaterkentsrus.com
PostPosted: Jun Sun 10, 2018 11:38 pm
There's another problem with this set.
The TA top is a #3676 Type 4, since it has no A+ and A- terminals in front of the tubes.
But that Type was only available in brown, not green.
All of the other #3676 types had the two A terminals in front.
A green TA would be a Type 1, 2, 3, or 6. Lack of parts mounted to the top indicates 1, 2, or 3.
It appears somebody took a top from another set and put it on this radio.
The #3676 was the most common TA, used on models throughout the breadboard era.
Ref: http://atwaterkent.info/Articles/AKRA0708.pdf
PostPosted: Jun Mon 11, 2018 12:21 am
I believe your correct. That's not good news. Acquiring the correct island will certainty add cost on top of whatever this set eventually sells for.
3676 TA unit
https://www.radiomuseum.org/r/atwater_t ... _3676.html
Michael Feldt
PostPosted: Jun Mon 11, 2018 1:04 am
I am pretty sure that the seller is an ARF member, so his listing update makes sense.
PostPosted: Jun Mon 11, 2018 2:16 am
The Coupled Circuit Tuner also has a chip missing at one of the mounting holes.
Jimmy
PostPosted: Jun Mon 11, 2018 3:10 am
Not to mention wrong wiring & spaghetti installed.
Too much spent on that Model 3.
_____________
xeric
N7CAH
PostPosted: Jun Tue 12, 2018 9:57 pm
I noticed that the knob on the variometer is only graduated from 50-0. All the ones I have and looking at 100's of oictures I have of AK variometers, all are graduated from 100-0. Has anyone here ever seen an AK knob like this with only 50-0 on the dial covering only 90 degrees instead of the normal 180 degrees of rotation??
Jimmy
PostPosted: Jun Tue 12, 2018 10:25 pm
Hi Jimmy,
That's interesting. I've never seen such a dial.
But it makes sense, since the adjustment range is only 90 degrees.
And the knob certainly looks the same as other AK knobs of that era.
on edit: spell-checker changed AK to OK. I changed it back to AK.
PostPosted: Jun Wed 13, 2018 5:55 pm
Well, that was depressing. I was trying to bid on the AK3 in the last few minutes, but ebay wouldn't let my bid go through. I kept trying on 2 different phones and 2 different computers, still couldn't get it to accept my bids. I tried with my local WIFI and without, still nothing. Did anyone else have any problems bidding, or was it just me?
Even now, I try to open up the completed auction and ebay won't let me see it. When I click on it, it say it's not available. All I can tell is that it went for a price below what I was bidding.
Jimmy
PostPosted: Jun Wed 13, 2018 6:10 pm
Don't take it personally, Jimmy.
Evilpay won't let me see the sale either.
It just puts up a page that says: "Something went wrong. We're sorry."
PostPosted: Jun Wed 13, 2018 6:20 pm
It looks like the winning bid was $777.67.
John KK4ZLF
PostPosted: Jun Wed 13, 2018 6:35 pm
https://www.ebay.com/itm/Atwater-kent-b ... _cvip=true
PostPosted: Jun Wed 13, 2018 6:42 pm
xeric wrote:
https://www.ebay.com/itm/Atwater-kent-breadboard-/153051639092?nordt=true&rt=nc&_trksid=p2047675.l2557&nma=true&si=MpWHpSLAvsNbFSX56XuogIK%252FcPw%253D&orig_cvip=true
That works. Thanks.
PostPosted: Jun Wed 13, 2018 9:23 pm
The "Something Went Wrong" page is just a glitch, if you hit the advanced search again it usually clears it. If the T/A is fixed the radio may be worth close to what was paid if parted out. I didn't like the looks of it when it was first auctioned,you could tell a monkey had gotten to it.
Dan
PostPosted: Jul Sun 01, 2018 12:17 pm
It looks like it has been relisted: https://www.ebay.com/itm/Atwater-Kent-B ... Swyf1bNl~G
GL,
Terry
Post New Topic Post Reply  [ 39 posts ]  Moderator: Lou deGonzague Go to page 1, 2  Next
Users browsing this forum: Instrument Fixer, k9uwa and 9 guests
