Author |
badrestorer
Post subject: Ever seen a refurbished vacuum tube? Posted: Jun Tue 30, 2015 3:00 pm |
Joined: Mar Mon 17, 2008 3:51 am Posts: 4231 Location: Conway, Arkansas
Top |
rocklandman
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jun Tue 30, 2015 3:05 pm |
Member |
Joined: Jun Mon 06, 2011 3:52 am Posts: 1184 Location: Hudson Valley NY
Why would anyone buy from him? You don't know what you will be getting, Ebay Roulette !! Not me !!
_________________ "Radios!!! I just can't get enough"!!!
Top |
Indiana Radios
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jun Tue 30, 2015 4:04 pm |
Member |
Joined: Sep Thu 14, 2006 3:27 pm Posts: 11610 Location: Carmel, Indiana
Quote: 6AX4/GT- 100% REFURBISHED VACUUM TUBE How do you refurbish a 6AX4 tube?
_________________ Michael Feldt
www.indianaradios.com
Top |
dan3460
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jun Tue 30, 2015 4:25 pm |
Joined: Nov Fri 15, 2013 10:17 pm Posts: 1991 Location: Haddon Heights NJ
Indiana Radios wrote: Quote: 6AX4/GT- 100% REFURBISHED VACUUM TUBE How do you refurbish a 6AX4 tube? Easy: you grab the tube, put some glass cleaner in there, clean all the dirt, shine the pins and put it in a new box. The tube has been refurbished and will read 100% on the tube tester scale.
_________________ I don't have a problem with buying radios, I can stop anytime I want!!!!
Top |
pixellany
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jun Tue 30, 2015 5:28 pm |
Member |
Joined: Jul Mon 26, 2010 8:30 pm Posts: 24630 Location: Annapolis, MD
Why, it's Mr. "bulk tester" again!!---he has a patent on how to test 4 or 5 tubes at the same time on one tube tester.
A while back, I attempted discussion with him. Unfortunately, there is no discernible input port.....
_________________ -Mark http://pixellany.com
Top |
wiscojim
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jun Tue 30, 2015 5:51 pm |
Joined: Sep Fri 07, 2007 2:27 am Posts: 5643 Location: Grand Chute, Wisconsin
Refurbished in electronics usually means tested to work with no defects.
If he tested his tubes and they were good with no defects, the use of the word "refurbished" is probably acceptable.
Top |
W7TFO
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jun Tue 30, 2015 6:02 pm |
Member |
Joined: May Fri 04, 2012 10:39 pm Posts: 1435 Location: Hidden Valley, AZ
That photo of the tester with a bunch of tubes stuck in it reminds me of an old Rodriguez cartoon from back in the 60's; The scene was one of those do-it-yourself standup testers in a store, and the guy had a lot of tubes in it, along with a small CRT. He was watching a ball game on it... The store manager come along and says "One at a time, buddy!" DDG
_________________ Workin' my Gramophone in a smartphone world.
Top |
Dave Wise
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jun Tue 30, 2015 8:40 pm |
Member |
Joined: Feb Thu 08, 2007 12:36 am Posts: 2136 Location: Hillsboro, Oregon
You described it well, made me chuckle. Wish I could see the original.
Top |
Eric H
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jun Tue 30, 2015 10:41 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 10269 Location: Redlands CA
wiscojim wrote: Refurbished in electronics usually means tested to work with no defects. . Refurbished to me means actually doing something to restore performance, like cleaning controls, replacing weak tubes, bad resistors & so on. Cleaning the outside of a tube doesn't improve it's performance one bit, unless the pins were filthy or had poor solder joints. I guess you could say you refurbished a tube if you resoldered the pins, at least on tubes that have a removable base.
Top |
Stan Ski
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jul Wed 01, 2015 12:55 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 10085 Location: Clinton Twp. Mi.
I sent this guy this message. Do you think he will answer?
You are selling your tube (or tubes) as being refurbished. Could you explain to me how you refurbish your tubes (in detail) . I have a lot of old radio tubes that i would love to refurbish. Also i noticed that you are able to test 6 tubes at a time. Wow! I am impressed. Could you also tell me how you do this? Sure would save me a lot of time. I wonder if you will include this message with your description and help out others that into tube radios Thank you for any help Stan Ski
Top |
doug-5er
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jul Wed 01, 2015 12:59 am |
Joined: Apr Mon 09, 2012 2:55 am Posts: 2437 Location: Lakewood,SoCal- 90713
What exactly is this guy selling for 65.50? I don't see a tube number.There are a lot of other adds that are the same way. I think this guy is a few fries short of a happy meal. http://www.ebay.com/itm/REFURBISHED-VAC ... 1c52d6072a
_________________ Doug
***"Your best teacher is your last mistake"***
Top |
AuroraOldRadios
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jul Wed 01, 2015 1:04 am |
Joined: Jul Sun 09, 2006 3:11 am Posts: 5922 Location: Aurora, CO
Terms that apply to modern electronics don't necessarily apply to hollow-state. Is there any period literature that says anything about refurbishing receiving tubes? Made me wonder- could you "test" rare transistors or ICs- say the rare output IC boards for Kenwood KR-9600 and call them refurbished? I still think it's misleading.
_________________ ex nihilo nihil fit
Top |
Dutch Rabbit
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jul Wed 01, 2015 2:36 am |
Member |
Joined: May Sun 13, 2012 8:12 pm Posts: 11697 Location: Central PA 16801
if he is going to refurbish tubes, (cough, cough, snort,  ) he needs to start refurbishing 45's, 10's 50's, WD11's, western electric 300B's, and RCA 2A3's. not the "so highly demanded" 6AX4. thanks for the post. it was a good laugh. steve
_________________ I am not responsible for any damage, injury, or death from any content / advice in this thread.
Top |
Eric H
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jul Wed 01, 2015 6:51 am |
Member |
Yeah, that'll put a Damper on sales.  (Damper, get it? because the 6AX4 is a damper tube, snort.)
Top |
Dutch Rabbit
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jul Wed 01, 2015 7:01 am |
Member |
yep !
steve
Top |
fifties
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jul Wed 01, 2015 10:51 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 30179 Location: SoCal, 91387
AuroraOldRadios wrote: I still think it's misleading. Tell it like it is...It's bulls..t.
_________________ \\\\\\\\\\\\\\\\\\\\\\\\He Who Dies With The Most Radios Wins//////////////////
Top |
dan3460
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jul Wed 01, 2015 4:43 pm |
Yeah, that'll put a Damper on sales.  (Damper, get it? because the 6AX4 is a damper tube, snort.) This is something that need to be rectified (clever ahh  ).
Top |
Stan Ski
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jul Wed 01, 2015 4:50 pm |
Member |
Really surprised he did answer me
I procure nos and bulk vacuum tubes, I clean them, straighten out any bent pins with my Hytron min pin straightening tool, After that, I visually inspect and re-label any of the larger tubes with part numbers as needed on their base with permanent stickers. Last two things really are what is included in Electronic Refurbishment of Components: I test all tubes (one at a time) and the strong ones 90-100% I recertify as good/pass, I repackage, and sell.these Refurbished Electronic Components just like I told you above. I hope that helps. perfectly good tubes into radios and audio systems all over the country.
Also for further definition of Refurbished just look up Wikipedia: REFURBISHED, ELECTRONIC COMPONENTS. That is what I do here like they explain, Radiobrain. Hopo that helps. Regards, MarkZ. BS., MS., ZTube
Stan Ski
Top |
dan3460
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jul Wed 01, 2015 4:58 pm |
Good that he clear that up, now what kind of tube he was selling for $65? and he pack his tubes ergonomically. Ergonomics is the studying of people in their working environments, so how do you pack people ergonomically? that will be a coffin. Therefore he packs his tubes in coffins
Top |
Dutch Rabbit
Post subject: Re: Ever seen a refurbished vacuum tube? Posted: Jul Wed 01, 2015 5:15 pm |
Member |
i have a B.S. and a M.S.
maybe i should sell tubes.
steve
Top |
Users browsing this forum: Copiertech and 11 guests |
