It is currently Jun Wed 20, 2018 4:58 am
 Post subject: RNY CL: Telefunken Montclair II
PostPosted: Oct Mon 10, 2016 1:18 am
Telefunken Montclair II on Rochester NY craigslist. Not my thing, but pretty cool looking. Ad says $95.00. Looks like top of the line?
http://rochester.craigslist.org/ele/5820910274.html
 Post subject: Re: RNY CL: Telefunken Montclair II
PostPosted: Oct Fri 21, 2016 6:32 pm
I ended up buying this unit. There's a group here that does a lot of estate sales. I bought it for 80$
The unit is beautiful. There is only one tiny scratch, but otherwise the finish is gorgeous.
I was on this site because I didn't know too much about this model.
Does anyone know what type of wood?
Does anyone know the year it was made?
It sounds nice, but one speaker is not working properly/fully.
The turntable does not work and if I touch the needle, no sound goes through to the speakers.
I haven't opened it up yet.
It did have a few manuals for the unit inside, which looked near mint. But they don't say details about the wood type or the year.
I'm debating fixing up the units inside or replacing the turntable with my own.
Thanks.
-Andy
Thanks.
-Andy
PostPosted: Jan Wed 11, 2017 9:17 pm
Andy, I am working on the exact same model. It turns on but lost all sound one day. I took it on as a "learning experience," I have done a bit of circuit repair in the past. The original owner left the unit with me to get working for their son. They said they bought it around 1974. Not sure about the type of wood. It looks like the cabinet and speaker system are Canadian, with electronics from Germany.
The Montclair II consists of a tuner-preamp unit with the control panel and rear jacks, and a separate solid state power amplifier/power supply unit mounted low in the center of the cabinet. The speaker system appears to be 16 ohm, 3-way.
Did you sort out the dead channel on your unit? The idler wheel pivot was stuck on the turntable in the system I am working on, preventing the idler wheel from contacting the motor shaft and platter rim. The turntable automatics are driven by the platter, so nothing will happen if the platter is not spinning. As for the turntable sound, make sure the signal wires are all connected to the PCB in the bottom of the turntable (female spade connectors fit into slots in the PCB) and the RCA-to-DIN adapter at the other end of the turntable lead is plugged into the corresponding plug in the rear jack panel of the tuner-pre panel.
I scoped the signal path, and the signal looks good out of the preamp into the power amp. There is signal with no speakers attached, but goes nearly dead as soon as the speakers are connected. I'm working on my fledgling power amp circuit knowledge to try to get to the bottom of it.
PostPosted: Mar Fri 31, 2017 5:58 pm
Thanks for the response. I have not done circuitry before and have limited experience with any of this stuff.
You information is very helpful, though, because I might be doing some of the learning process repair stuff myself.
I'm in Rochester, NY and one person here agreed to take it on, but then changed their mind. He thought it was too big, would take too long, and would cost too much to repair for me.
So now I'm looking for other options for repair people locally.
One guy in town says he'll take a look, but he thought I was making up the brand name (never a good sign).
So I'm looking around some more.
I'll probably give your info to the repair guy so he gets a head start at things.
Good luck with yours!
-Andy
PostPosted: Mar Fri 31, 2017 10:30 pm
A lot of the carbon resistors in the 60s and 70s german radios drift up. I got a Saba Konstanz 18 (made in 1967) for a low price because one side was out on it. I changed the carbon resistors and I was back in business. It's a beautiful console. Wish I had room for something like that. Regardless, I am sure the issue isn't dire. Hope it is just a resistor.
Shawn
PostPosted: Jun Tue 19, 2018 7:35 pm
The unit I was working on is now fully functional (well, almost...more on that later). The electrolytic coupling capacitors in the power amplifier were dead. I replaced them with good quality Nichicon and the system came back to life. I ended up replacing all of the electrolytics in the power amp since they were easily accessible and replacements are cheap. I also replaced the four electrolytics on the FM stereo decoder board in the tuner-preamp (the ~3" square board which "plugs" into the nail-like pins on the main tuner-pre board beside the ferrite antenna. The FM radio sounded fine in mono, but lost all low end when playing in stereo.
I replaced both midrange drivers (torn cones) with GRS 5SBM1-8's from Parts Express. They are slightly smaller than the factory drivers, but fit inside the four original studs and I was able to use washers under the original nuts to "grab" the outside edge of the frame. This was a significant sonic improvement, likely from the original sound quality let alone the torn speaker cones.
I say the unit is "almost" fully functional because during my blissful "road test" of the system after getting everything back together, the washer/plate retaining the upper bearing in the turntable motor fell out of it's home rendering the motor non-functional. Luckily, it appears to be serviceable. There don't seem to be many Perpetuum-Ebner turntables outside of Europe, so I'm not holding my breath for a parts deck.
Post New Topic Post Reply  [ 7 posts ]  Moderator: Lou deGonzague
Users browsing this forum: andyjon100, VntgRads and 7 guests
