It is currently Feb Mon 19, 2018 12:31 pm
Post New Topic Post Reply  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: Single ended amplifier
PostPosted: Oct Wed 11, 2017 7:22 pm
Unless you are using a very efficient speaker 2 watts at 8% distortion which may actually be around 1.5 watts undistorted will not be nearly enough.
Suggest using a higher B+ voltage such as 250-300 volts and re-bias accordingly.
Look at any schematic of a radio using the 6V6 tube single ended and duplicate the parts values and how it is connected along with the B+ voltage.
If you can draw up a schematic of the amp as it currently is connected and post it here I can further help determine what components should be used and what B+ needs to be.
Now if you want a higher B+ voltage using the same transformer then ditch the 6X5 and use a couple diodes in its place which will give an unloaded B+ of 254.52 Vdc.
That should be enough to get you around 4.5 watts of audio.
PostPosted: Oct Wed 11, 2017 9:43 pm
I'm not sure that the 180v B+ isn't enough Tuberadio.
I say that based on the performance I get from my (6v6-like) 5902 PP amp where I'm only using 140v B+.
It's quite loud enough to fill the house.
PostPosted: Oct Wed 11, 2017 10:05 pm
Here's an Airline radio 35wg-1573B using the 6V6 at 185v on the plate .... and a 6X5 rectifier
It uses a 300 ohm cathode bias resistor at 8.8v bias
airline 35wg-1573b.pdf [135.38 KiB]
Downloaded 30 times
PostPosted: Oct Thu 12, 2017 12:05 am
Yours is push pull though.
PostPosted: Oct Thu 12, 2017 12:42 am
Yes... but the Arline 35wg-1573B ... is not.
And it has 185v on the plate and they use a 6X5
Cathode resistor 300 ohms 8.8v bias
Users browsing this forum: w3jn and 4 guests
