It is currently Jun Wed 20, 2018 8:35 am
 Post subject: 10 meter coil info.
PostPosted: Jun Wed 13, 2018 3:47 pm
Hi all, Several years ago I built the Hart 25 CW transmitter.
It used a 5Y3 and a 6W6GT. and worked well on 40 and 80
meters.
My question is can I use this little 5 W output transmitter
on 10 meters?
I know I'll have to change to a 20mc. crystal,
What coils would I need to work 10 M
What I'm saying is, I need to know What wire size and
How many turns.
For 40 m. it's Plate is 31 turns of #20 wire close wound
Antenna coil 18 turns # 20 wire. I wound them on a pill
bottle. So what about 10M.
Thanks for any help,
Gary KB3WYZ
 Post subject: Re: 10 meter coil info.
PostPosted: Jun Wed 13, 2018 7:20 pm
Gary T. Lane wrote:
My question is can I use this little 5 W output transmitter on 10 meters?
Hi Gary,
You better change to a 28Mc crystal unless you want to operate on 15 meters.
Or 14Mc if the oscillator or buffer can be configured to work as a doubler.
PostPosted: Jun Wed 13, 2018 10:33 pm
Ok I meant 28mc..
Right now I have the 40&80 meter coils.
How many turns and what size wire and form diameter
should I use?
Gary :?
PostPosted: Jun Thu 14, 2018 2:56 am
Most rigs from that era multiplied to 20, 15, and 10 meters. So why would he need a 28mc/s crystal? You might even need to add a multiplier stage. Also I suspect that even if the rig doubled/tripled/quadrupled to 20, 15, or 10 meters I am not sure it would meet the spectral purity for current rigs.
Even then old rigs like the Eico 720 or DX-## could be easily tuned to the wrong harmonic of that crystal. Ask me how I know.
Thank you.
Jim
PostPosted: Jun Thu 14, 2018 3:03 am
Spectral purity is the main reason I suggested a 28Mc crystal in the first place.
I expect the 28Mc crystal would be a 3rd overtone, but still cleaner than multiplier output.
PostPosted: Jun Thu 14, 2018 3:17 am
6W6 was not designed as an RF amplifier, but it will work. Efficiency may not be good and you may get some strange oscillation at 28 Mhz.
I remember guys used to cut the bases off of 6L6 and 1625 to get better performance above 20 Mhz.
PostPosted: Jun Thu 14, 2018 3:22 am
Octal tubes as originally designed had just wire leads, with no base.
I guess going back to the original design was beneficial in this case.
PostPosted: Jun Fri 15, 2018 5:32 pm
Gary T. Lane wrote:
Ok I meant 28mc. Right now I have the 40&80 meter coils. How many turns and what size wire and form diameter should I use? Gary :?
Gary, check out this inductance calculator. I've found that it correlates nicely with measured results. Values will depend on your specific circuit and desire for the tuned element.
http://hamwaves.com/antennas/inductance.html
73, Dean, NW2K
