Page 1 of 1
[ 14 posts ] |
| Author |
jkoebel
Post subject: 6V6 Kit Amp - Schematic drawn wrong? Posted: Feb Wed 29, 2012 10:25 pm |
Joined: Aug Thu 27, 2009 7:47 am Posts: 1835 Location: Seattle
I'm building up a no-name kit amplifier. 6SL7 driving P-P 6V6s, two identical channels for stereo. I haven't started wiring it up yet, was just going over the schematic before doing so and see what looks like an inaccuracy:  The way its drawn, looks like the sections of the 6SL7 are directly coupled to one another...the grid of the phase inverter would have the same B+ as the plate of the driver. Did they leave out a cap, or should C2 (39pF) be moved above the tie point, or am I just not understanding something about that tube?
| Top |
John Bartley
Post subject: Re: 6V6 Kit Amp - Schematic drawn wrong? Posted: Feb Wed 29, 2012 11:38 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4524 Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K 1P0
jkoebel wrote: I'm building up a no-name kit amplifier. 6SL7 driving P-P 6V6s, two identical channels for stereo. I haven't started wiring it up yet, was just going over the schematic before doing so and see what looks like an inaccuracy:  The way its drawn, looks like the sections of the 6SL7 are directly coupled to one another...the grid of the phase inverter would have the same B+ as the plate of the driver. Did they leave out a cap, or should C2 (39pF) be moved above the tie point, or am I just not understanding something about that tube? No, there's not likely a mistake. I have a Mason guitar amp, similar circuit, 6SL7 (iirc), preamp direct coupled to the inverter (iirc). It plays great! I'll try to find the schematic for you. cheers John
_________________ Looking for an old friend - Dan Lafleur, from Carp, Ontario, who attended Earl of March High School.
| Top |
Tubenut
Post subject: Re: 6V6 Kit Amp - Schematic drawn wrong? Posted: Feb Wed 29, 2012 11:48 pm |
Joined: Oct Sun 11, 2009 10:06 am Posts: 1441 Location: British Columbia
| Top |
battradio@
Post subject: Re: 6V6 Kit Amp - Schematic drawn wrong? Posted: Feb Wed 29, 2012 11:55 pm |
| Member |
Joined: Jul Fri 18, 2008 10:02 am Posts: 1373 Location: near ST Louis Mo
Thats a very common and cheep way to make a phase inverter
_________________ Mark
| Top |
Flipperhome
Post subject: Re: 6V6 Kit Amp - Schematic drawn wrong? Posted: Mar Thu 01, 2012 1:01 am |
| Member |
Joined: Nov Sat 26, 2011 4:09 am Posts: 1056 Location: Texas. USA
jkoebel wrote: The way its drawn, looks like the sections of the 6SL7 are directly coupled to one another...the grid of the phase inverter would have the same B+ as the plate of the driver. That's a normal concertina arrangement and intended to not need a cap. V1a current and load resistor are chosen so that plate volts will properly bias the concertina, otherwise you'd need an extra cap and another resistor (grid leak) under V1b to set bias. The second approach is also done but it's desirable to eliminate the cap since they make it more difficult to stabilize the amp after negative feedback. The C and R from grid to ground are for just that, rolling off high frequency (the R forms a shelf limiting the cut) so the amp is more stable with the negative feedback.
| Top |
jkoebel
Post subject: Re: 6V6 Kit Amp - Schematic drawn wrong? Posted: Mar Fri 02, 2012 2:19 am |
Glad I asked! Now I'm that much smarter. Thanks for the input everyone.
| Top |
radiotechnician
Post subject: Re: 6V6 Kit Amp - Schematic drawn wrong? Posted: Mar Sat 03, 2012 2:35 am |
Joined: Sep Thu 23, 2010 6:37 am Posts: 4086 Location: Powell River BC
Could you post the values of the resistors: They are not too clear for me. The grid connected to the plate is interesting but of more interest would be the cathode voltage of the phase inverter section of the 6SL7.
| Top |
jkoebel
Post subject: Re: 6V6 Kit Amp - Schematic drawn wrong? Posted: Mar Mon 05, 2012 7:22 pm |
Sure...I annotated the schematic and cropped to just the signal path, leaving the power supply off.  I'm also somewhat unclear about why the decision to use two 680 Ohm resistors in parallel with each other for the cathode resistors on the 6V6s. Two 680R / 5W in parallel is 340R 10W...maybe they just didn't want to use a 10W resistor there.
| Top |
Flipperhome
Post subject: Re: 6V6 Kit Amp - Schematic drawn wrong? Posted: Mar Mon 05, 2012 11:29 pm |
| Member |
radiotechnician wrote: ...of more interest would be the cathode voltage of the phase inverter section of the 6SL7. I ran a quick simulation and, assuming B+ comes out around 330V, V1B cathode is about 80V.
| Top |
jkoebel
Post subject: Re: 6V6 Kit Amp - Schematic drawn wrong? Posted: Mar Tue 06, 2012 12:32 am |
B+ comes off a transformer with a 255V secondary (non-CT), into a bridge rectifier...B+ to the output transformer comes right off there (with a 470uF cap); B1+ to the front section through a 3.3K resistor in the power supply also filtered with a 470uF cap. There's a 220K bleeder between B+ after the first filter (and before the 3K3) and B-.
For what that's worth.
| Top |
Flipperhome
Post subject: Re: 6V6 Kit Amp - Schematic drawn wrong? Posted: Mar Tue 06, 2012 1:20 am |
| Member |
That matches what I was able to gleen from the original posted pic. At the end of the day actual B+ will depend on winding resistance, loading, etc, so I just used a 1.3 'rule of thumb' factor to get the 330V ballpark figure.
Cathode volts will also vary from tube to tube so that's just a ballpark number too.
| Top |
N0BST
Post subject: Re: 6V6 Kit Amp - Schematic drawn wrong? Posted: Mar Fri 09, 2012 5:03 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1003 Location: Cambridge MN USA
I'm surprised at what they used in the cathode circuit of the PP 6V6s. Likely they could have gotten away with just ONE 330R instead of the pair of 680s. Plus the bypass cap shouldn't be necessary as the current will be pretty steady as one tube starts to shut down and the other conducts more heavily.
Scott Todd
| Top |
Flipperhome
Post subject: Re: 6V6 Kit Amp - Schematic drawn wrong? Posted: Mar Fri 09, 2012 7:21 am |
| Member |
N0BST wrote: Plus the bypass cap shouldn't be necessary as the current will be pretty steady as one tube starts to shut down and the other conducts more heavily. That only applies Class A.
| Top |
John Bartley
Post subject: Re: 6V6 Kit Amp - Schematic drawn wrong? Posted: Mar Sat 10, 2012 2:44 am |
John Bartley wrote: No, there's not likely a mistake. I have a Mason guitar amp, similar circuit, 6SL7 (iirc), preamp direct coupled to the inverter (iirc). It plays great! I'll try to find the schematic for you.
cheers
Here's the schematic and parts list that I drew up before I recapped my Mason V amp:  Mason Model 5 Guitar Amplifier
The Galt Musical Instruments Company
(made in Canada circa 1950)
Resistors :
1) 100k 2) 100K 3) 560 4) 470k - 1W 5) 100k 6) 500k - Volume 7) 200 8 ) ??? - NFB 9) 1.2 meg 10) 2.2 meg 11) 220k - 1W 12) 220k - 1W 13) 470k - 1W 14) 470k - 1W 15) 500 - 10W 16) 50k - 1W 17) 4.7k- 1W
Capacitors :
a) 10 / 40v b) .05 / 600v c) .005 / 600v d) .05 / 600v e) .05 / 6300v f) 50 / 40v g) 20 / 450v h) 20 / 450v i) 8 / 200v j) .01 / 600v
| Top |
Page 1 of 1
[ 14 posts ] |
