It is currently May Sat 25, 2013 3:26 am
 Post subject: a look alike radio of the 1920 's
PostPosted: Mar Mon 26, 2012 5:55 pm
A few months ago I started a project.I had the intension to make a radio like they made in the 1920 's.All the brass components are home brew.The black plates are made of original ebonite It is a tree valve radio with hi frequentie valve,a detector and one low frequentie valve.The green coil is a hf filtering coil./The set is already playing but now I am bussy to make a deasent cabinet in cherrywood like the original..The cabinet you see now is made of wine boxes.This was a tryout.A perfect copy of a Ducretet.I dind not make a copy of an existing radio but had myy own inspiration working and made mu own model model.When everything is finische I wil post some pictures.
Last edited by freddy vercruyce on Mar Mon 26, 2012 6:53 pm, edited 1 time in total.
 Post subject: Re: a look alike radio of the 1920 's
PostPosted: Mar Mon 26, 2012 6:18 pm
This is amazing work with 1920's inspiration. You were clearly born in the wrong era! Thanks for sharing these pictures of your work.
Curtis Eickerman
PostPosted: Mar Tue 27, 2012 11:25 pm
Wow, what a lovely job, I can see lots of hours in the shop in those pictures. Good work! It will look even better in cherry.
PostPosted: Mar Wed 28, 2012 5:30 pm
Thakls for your comments.I think by sonday the small furniture will be ready to color and polisch (politour with schellac ) the anciant way like it was done for the expensive sets in that time.Kind regards Freddy
PostPosted: Mar Thu 29, 2012 8:47 pm
here it is.The cabinet is finisched.It looks better than the wine case wood cabinetdosn't it.I didn't make it myself but a fellow collector made it for me.He is also a professional funituer maker.Now there are some minor détail I have to finisch and then up to the next project
Ps: I wonder if over in the states wireless like Ducretet,Vitus ao continental set from the 20's are wanted/or in your collection.Here a pic from my VITUS mondial I.Completely 100% original and playing.Unbeleveble a set from 1924 and still playing.
kind regards Freddy
PostPosted: Apr Thu 05, 2012 9:07 pm
Freddy,
That is a beautiful job. I am attempting to do some similar work but will probably never reach your level.
I like you approach of using secondary wood for the first attempt. I have been searching for what wood species was used in the 1920, '30s for cabinets. No one I have talked to seems to really know. You used cherry for your project. Cherry is easy to get here and I think that is what I will use.
Again, good job,
Lyn
PostPosted: Apr Sun 15, 2012 10:12 am
What did you use for the front and top panel?
Brian
I came into this world with nothing...
I have been able to keep most of it.
PostPosted: Apr Sun 15, 2012 8:23 pm
Dyne O Mite! Great work Freddy. Where in the world are you? We could use your talents in the US of A anytime :mrgreen:
Dale
PostPosted: Apr Mon 16, 2012 9:07 pm
Hello I used ebonite( vulcanised rubber ) like thy did in the early 20 's.This is not avayleble any more but I had the chance to aquire a peace of 1.80x 80 cm without any holes drilled in it.Kind regards Freddy
PostPosted: Apr Mon 16, 2012 9:09 pm
Dale
Thanks for your compliments Freddy
PostPosted: Apr Mon 16, 2012 9:27 pm
tjugofyra wrote:
Freddy,
Again, good job,
Lyn
Hello Here a little update with a picture of the cabinet as it is now.I still haven to ingrave the scales for de variable condensor and the variocoupler. I also added a picture of one of the little brass inscription plates.Also home brewedKind regards Freddy
PostPosted: Apr Mon 16, 2012 9:43 pm
tjugofyra wrote:
Freddy,
Again, good job,
Lyn
Hello For the realy exensive sets they used or nuts-wood or cherry wood.Sometimes also mahony Kind regards freddyy
Users browsing this forum: threeneurons and 2 guests
