Page 1 of 1
[ 15 posts ] |
| Author |
easyrider8
Post subject: 1KHz to 33MHz Adjustable Oscillator Module Board Posted: Apr Thu 12, 2012 2:01 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6765 Location: Minnesota
| Top |
Flipperhome
Post subject: Re: 1KHz to 33MHz Adjustable Oscillator Module Board Posted: Apr Thu 12, 2012 2:21 am |
| Member |
Joined: Nov Sat 26, 2011 4:09 am Posts: 937 Location: Texas. USA
| Top |
easyrider8
Post subject: Re: 1KHz to 33MHz Adjustable Oscillator Module Board Posted: Apr Thu 12, 2012 4:40 am |
That one is different.
| Top |
Flipperhome
Post subject: Re: 1KHz to 33MHz Adjustable Oscillator Module Board Posted: Apr Thu 12, 2012 6:09 am |
| Member |
It's not only the same one but he got it from the same Ebay store, electronics-salon.
| Top |
Dave Doughty
Post subject: Re: 1KHz to 33MHz Adjustable Oscillator Module Board Posted: Apr Thu 12, 2012 12:46 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 13632 Location: Utica, NY 13502 (USA)
Yeah - that's the same one I bought but Dave's cost $1.00 less. I think the confusion is because my thread started out experimenting with an ancient XR2206 chip but then went OT and discussed this module which definitely seems like an improvement.
| Top |
Tubenut
Post subject: Re: 1KHz to 33MHz Adjustable Oscillator Module Board Posted: Apr Thu 12, 2012 6:34 pm |
Joined: Oct Sun 11, 2009 10:06 am Posts: 1441 Location: British Columbia
Hi Dave. I see you mention the XR2206's drift in the other thread. What kind of drift did you encounter with the LTC1799? I see their quite cheap at digikey.
| Top |
Dave Doughty
Post subject: Re: 1KHz to 33MHz Adjustable Oscillator Module Board Posted: Apr Thu 12, 2012 11:41 pm |
It was more like instability due to the adjustment pots rather than drift. It was hard to set an exact frequency but I think with a fixed resistor and a lower value fine tuning pot, it would be fairly stable. When I was finally able to zero beat a broadcast station, it stayed within about 50 Hz.
| Top |
Tubenut
Post subject: Re: 1KHz to 33MHz Adjustable Oscillator Module Board Posted: Apr Fri 13, 2012 3:34 am |
Ok Dave. 50Hz isn't bad... I have 5 on order from digikey. I will do a little experimenting. Thanks for the info.
| Top |
Peter Bertini
Post subject: Re: 1KHz to 33MHz Adjustable Oscillator Module Board Posted: Apr Fri 13, 2012 3:12 pm |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 12191 Location: Somers, CT
TubeNut:
If you have a good SA, I'd be curious what the phase noise/jitter looks like in the HF region. Circuit looks like a RC oscillator with a divider chain.
Pete
_________________ A long journey always begins with the words, "I think I know a shortcut."
| Top |
Peter Bertini
Post subject: Re: 1KHz to 33MHz Adjustable Oscillator Module Board Posted: Apr Fri 13, 2012 4:37 pm |
| Moderator |
BTW, anyone have a link to Norm Leal's single tube "part 15" single tube AM transmitter?? I'd be willing to try one of these as a replacement for the fixed frequency crystal osc. assembly he used in the original design.
Pete
| Top |
35Z5
Post subject: Re: 1KHz to 33MHz Adjustable Oscillator Module Board Posted: Apr Fri 13, 2012 4:46 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8650 Location: Chesapeake VA
| Top |
Peter Bertini
Post subject: Re: 1KHz to 33MHz Adjustable Oscillator Module Board Posted: Apr Fri 13, 2012 6:02 pm |
| Moderator |
Great! I will order a few of those modules today. By any chance do you have a link to to Norm's 12k5 space charge receiver project?
Pete
| Top |
35Z5
Post subject: Re: 1KHz to 33MHz Adjustable Oscillator Module Board Posted: Apr Fri 13, 2012 8:15 pm |
| Member |
| Top |
Tubenut
Post subject: Re: 1KHz to 33MHz Adjustable Oscillator Module Board Posted: Apr Fri 13, 2012 9:06 pm |
Im purdy sure, without any filtering network on the output, the signal is probably full of harmonics. There is a divider inside too. I will fool with it when I get some time and let you guys know.
| Top |
Dave Doughty
Post subject: Re: 1KHz to 33MHz Adjustable Oscillator Module Board Posted: Apr Fri 13, 2012 10:02 pm |
Tubenut wrote: Im purdy sure, without any filtering network on the output, the signal is probably full of harmonics. There is a divider inside too. Perhaps a low-pass filter on the grid input would be the thing to do. I just experimented with replacing the crystal on my 5-watt LPB college transmitter. It worked well and the output was a sine wave. But it uses a 6AL11 compactron where the pentode section was the oscillator and the power pentode section has a tuned output stage. Dave
| Top |
Page 1 of 1
[ 15 posts ] |
Who is online |
Users browsing this forum: No registered users and 3 guests |
