It is currently Jun Tue 18, 2013 11:11 pm
 Post subject: crystal radio meets DOE EERE
PostPosted: Apr Tue 24, 2012 6:44 pm
I used two of the garden solar lights in series to power the LM 386 audio amp.
It will work with the 2 fully charged cells, although only with the volume about 25%.
It will run about 2.5 hrs with the 2 cells before it starves for power.
I plan to add more so the low end research is moot. However it will run limited vol with 2 cells
There are several configurations of the garden solar units.
One I used has the day cutoff sensor, and a cheaper unit (.50 cents on closeout) that's always on.
I ripped out the guts to that one (never did work..
It will charge the cell anyway, but a diode should be installed to keep from reverse discharge at night
I plan to take this further as the lights in wife's garden "go bad " or I find them on closeout such as after a holiday. A bunch of them charging a bank of cells? Or a a little wire from the bushes through the window that
is off the grid. Maybe someone will run with this. I certaintly feel better now about the zero carbon footprint
From the crystal Radios.
davep
 Post subject: Re: crystal radio meets DOE EERE
PostPosted: Apr Tue 24, 2012 6:52 pm
Most garden lights contain a "Joule Thief" circuit. This boosts the 1.2 V battery voltage up to about 3.6V to light the white LED. The ones I took apart operated at 520 KHz., so if you don't disable the "Joule Thief" you may get RFI bothering your radio and amplifier.
http://rustybolt.info/wordpress/?p=741
PostPosted: Apr Tue 24, 2012 11:46 pm
Cute tuning knob!
Reece
PostPosted: Apr Wed 25, 2012 11:15 am
Hey Dave.
Nice looking rig.Sounds like fun to mess around w/ those garden lights.
K
