It is currently May Fri 24, 2013 3:17 pm
 Post subject: My 2 Tube 1924 Reflex radio sounds like this...
PostPosted: Apr Wed 18, 2012 1:49 am
Been working on a 2 tube reflex radio from a 1923-24 Radio Broadcast publication and thought I would share what I now hear. Just 9 seconds though, click on the picture. :)
Brian
I came into this world with nothing...
I have been able to keep most of it.
 Post subject: Re: My 2 Tube 1924 Reflex radio sounds like this...
PostPosted: Apr Sat 21, 2012 5:46 am
Love it!
Hank 8)
PostPosted: Apr Mon 23, 2012 12:58 pm
Awesome.
PostPosted: Apr Mon 23, 2012 9:11 pm
Sounds great! What sort of sensitivity are you getting from it, as far as DX stations?
PostPosted: Apr Mon 23, 2012 9:15 pm
I can pull in a lot of stations at night but the selectivity is bad.
Looking at building a 2 tube Doerle to replace this - just have not found the coil data for MW.
Brian
PostPosted: Apr Tue 24, 2012 11:52 pm
Great, and how appropriate that you tuned in KDKA, that station being a pioneer and about four years old when your radio plans were published.
Reece
PostPosted: Apr Wed 25, 2012 1:37 pm
The 2 tube Doerle is a sweet perfomer. Good sensitivity and selectivity. I can listen to a strong station across the room using 45V B+.
Calculate your coil to fit your variable capacitor. To tune MW you will need at least 365pF. 400 pF would be better.
Mark
PostPosted: Apr Wed 25, 2012 9:38 pm
The higher the C the higher the Q and selectivity, even 1000pf for the low BCB isnt excessive and Cardwell made them in the 20's with a fairly small .030" spacing so they arent for big transmitters.
Of course a 2 or 3 gang 365-400pf BC style could be wired in parallel.
PostPosted: Apr Wed 25, 2012 10:35 pm
Brian:
Do a Google search for Bill "Exray" Meacham's contact information. He built some 2 tube Doerle's in the past and can probably provide you with all of the information, coil and otherwise, that you'll need.
In fact, Bill built quite a few homebrews...that you'll see once you've located his webpage.
BR,
Terry
PostPosted: Apr Thu 26, 2012 12:03 am
radioterry wrote:
Do a Google search for Bill "Exray" Meacham's contact information...
Bill's website is here:
http://sparkbench.com/
A contact email address is there.
His 2-tube Doerle is shown on this page:
http://www.sparkbench.com/homebrew/homebrew.html
PostPosted: Apr Thu 26, 2012 2:41 am
BTW there are at least 2 different 2 tube Doerle circuits out there. One uses a throttle capacitor another uses a pot on the B+ to control the regen.
I prefer the B+ control because pots are cheaper (especially if you are using vintage components), easier to mount, not sensitive to hand capacitance and I have found they are less touchy, and require less adjustment as you change frequency.
I also omit the antenna capacitor or winding and just use a "gimmick" capacitor by wrapping an alligator lead around the antenna lead in. (Antenna length is a factor here.)
Kevin "krystallo" can verify that my 2 tube Doerle works best with an alligator clip simply clipped onto the insulation of my 300' longwire lead-in.
Your mileage may vary.
Mark
PostPosted: Apr Thu 26, 2012 12:49 pm
I have visited Bill's site many times.
Thanks for the link
Brian
