It is currently May Mon 20, 2013 3:06 am
 Post subject: IF Transformers
PostPosted: Jul Thu 05, 2012 7:35 pm
I'm looking at a project from the 50s that uses 1500 Khz IF transformers. I haven't been able to locate the Millen type specified and don't have a good feel for the input/output impedences. I began wondering if it was possible wind a toroid core bifiler to use for this purpose - with variable resonating caps to use for peeking. Has anyone done something like that?
arnie - W1GCI
 Post subject: Re: IF Transformers
PostPosted: Jul Fri 06, 2012 3:18 am
No, way too much coupling doing it that way. You can do two individual LC resonant toroids and use a 1-2 turn link on each to couple them. That still gives pretty tight coupling but it might be ok depending on your application. Next step would be adding a small cap in series with the link.
Not too long ago one of the guys here posted a question about some 1500-1600 xfmrs that he fell into. I was waiting for a FS ad to show up because I would have been interested. Never saw it. Might be able to search back and contact him?
The beatings will continue until the morale improves
PostPosted: Jul Fri 06, 2012 12:39 pm
The early single conversion cb radios used 1650 KC IF's. eBay generally has some junkers listed that go cheaply. These transformers will probably tune 1500 KC unmodified. If necessary, add a small amount of capacitance across the windings.
Darrell
PostPosted: Jul Fri 06, 2012 3:48 pm
Arnie
How about working with AM broadcast band antenna coils?
PostPosted: Jul Sun 08, 2012 1:48 pm
Thanks to everyone that replied. I wasn't thinking about the coupling requirements. Jack's idea about using two cores and link coupling the two together seems like a really good approach. I think I'll give it a try.
arnie
PostPosted: Jul Mon 09, 2012 12:56 am
I have a virgin Miller, Cat. No. 612-W2 Iron Core 2nd I.F. 1400-1600 KC
It's a 1"x1"x3" can with two adj. screws
Yours for the asking.
Ed
Users browsing this forum: tanglong2009 and 2 guests
