Page 1 of 1
[ 6 posts ] |
| Author |
Arnie-AE
Post subject: IF Transformers Posted: Jul Thu 05, 2012 7:35 pm |
Joined: Aug Tue 18, 2009 1:46 pm Posts: 457 Location: Berlin, MA
I'm looking at a project from the 50s that uses 1500 Khz IF transformers. I haven't been able to locate the Millen type specified and don't have a good feel for the input/output impedences. I began wondering if it was possible wind a toroid core bifiler to use for this purpose - with variable resonating caps to use for peeking. Has anyone done something like that?
arnie - W1GCI
| Top |
Jack Shirley
Post subject: Re: IF Transformers Posted: Jul Fri 06, 2012 3:18 am |
| Member |
Joined: Mar Fri 14, 2008 1:40 pm Posts: 8405 Location: SE USA
No, way too much coupling doing it that way. You can do two individual LC resonant toroids and use a 1-2 turn link on each to couple them. That still gives pretty tight coupling but it might be ok depending on your application. Next step would be adding a small cap in series with the link.
Not too long ago one of the guys here posted a question about some 1500-1600 xfmrs that he fell into. I was waiting for a FS ad to show up because I would have been interested. Never saw it. Might be able to search back and contact him?
_________________ The beatings will continue until the morale improves
| Top |
hbr nut
Post subject: Re: IF Transformers Posted: Jul Fri 06, 2012 12:39 pm |
The early single conversion cb radios used 1650 KC IF's. eBay generally has some junkers listed that go cheaply. These transformers will probably tune 1500 KC unmodified. If necessary, add a small amount of capacitance across the windings.
Darrell
| Top |
Norm Leal
Post subject: Re: IF Transformers Posted: Jul Fri 06, 2012 3:48 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 28951 Location: Livermore, CA
Arnie
How about working with AM broadcast band antenna coils?
_________________ Norm
| Top |
Arnie-AE
Post subject: Re: IF Transformers Posted: Jul Sun 08, 2012 1:48 pm |
Thanks to everyone that replied. I wasn't thinking about the coupling requirements. Jack's idea about using two cores and link coupling the two together seems like a really good approach. I think I'll give it a try.
arnie
| Top |
Hilly-wa
Post subject: Re: IF Transformers Posted: Jul Mon 09, 2012 12:56 am |
I have a virgin Miller, Cat. No. 612-W2 Iron Core 2nd I.F. 1400-1600 KC
It's a 1"x1"x3" can with two adj. screws
Yours for the asking.
Ed
| Top |
Page 1 of 1
[ 6 posts ] |
Who is online |
Users browsing this forum: No registered users and 1 guest |
