| Author |
MrE12AX7
Post subject: I want to build a superhet Posted: Jul Sat 21, 2012 5:02 pm |
| Member |
I would like to build a superhetrodyne with normal tube s in space-charge mode audio output tube will be a 12k5 and the rest of the tubes are 12av6 12ba6 12be6 I have large style I.F transfomers and a junker aa5 chassis i dont want to wind coils
_________________ ''What's With All The Quotes In Everyone's Signatures''
| Top |
Eickerman
Post subject: Re: I want to build a superhet Posted: Jul Mon 23, 2012 4:38 pm |
| Member |
| Top |
MrE12AX7
Post subject: Re: I want to build a superhet Posted: Jul Mon 23, 2012 7:22 pm |
| Member |
ok i will look at the Japanese site in google translate
| Top |
35Z5
Post subject: Re: I want to build a superhet Posted: Jul Mon 23, 2012 7:36 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8656 Location: Chesapeake VA
Actually the low voltage car radio tubes are just that, low voltage... Except for the tetrodes that were generally used as drivers for audio or power tuning, none operate in space charge mode... You can use AA5 types on low voltage, but the types designed to operate at 12v will perform better... http://www.wa2ise.com/radios/12ba7.html#aa5 Tom
| Top |
MrE12AX7
Post subject: Re: I want to build a superhet Posted: Jul Mon 23, 2012 7:37 pm |
| Member |
what about using battery radio tubes (eg 1r5 1u5 3v4)
if not I will get the space charge tubes and I have 12k5 tubes
| Top |
35Z5
Post subject: Re: I want to build a superhet Posted: Jul Mon 23, 2012 7:53 pm |
| Member |
Due to their somewhat delicate filament, I'm not a fan of the battery tubes for experimentation(at least in multiples)... They could be no doubt be used, I'd guess B+ should be in the 25-30v range for best performance, probably same for AA5 types...
A 25v CT transformer would supply the higher B+ & each leg could be used for 12v to operate the heaters...
| Top |
MrE12AX7
Post subject: Re: I want to build a superhet Posted: Jul Mon 23, 2012 8:59 pm |
| Member |
I will go with the 12v tubes on a all 12v circut
| Top |
fifties
Post subject: Re: I want to build a superhet Posted: Jul Mon 23, 2012 10:13 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8768 Location: SoCal, 91387
35Z5 wrote: I'd guess B+ should be in the 25-30v range for best performance, probably same for AA5 types...
Tom Every portable Superhet using batteries that I've collected so far requires either a 45 or 67.5 volt B supply. Heaters light with but one C or D cell. I've even used an AA in a Koyo Parrot with the submini "peanut" tubes. Even a three tube earphone-only set requires a 45 volt battery.
_________________ *******\\\\\\\\\******He Who Dies With The Most Radios Wins******/////////*******
| Top |
Norm Leal
Post subject: Re: I want to build a superhet Posted: Jul Mon 23, 2012 10:44 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 28969 Location: Livermore, CA
Built a lot of radios using 1 1/2 volt tubes. They are best for battery use (portable) but require two voltages.
Tom posted an interesting circuit that I've never seen. Car radios used an additional transistor stage. This one only requires 12 volts @ 1 amp. Easy to make power supply.
_________________ Norm
| Top |
MrE12AX7
Post subject: Re: I want to build a superhet Posted: Jul Mon 23, 2012 10:56 pm |
| Member |
I am using the 12v car radio tube tubes so they only require 12vdc on the plate
| Top |
35Z5
Post subject: Re: I want to build a superhet Posted: Jul Mon 23, 2012 11:29 pm |
| Member |
fifties wrote: Even a three tube earphone-only set requires a 45 volt battery. They'll no doubt operate on much less than 45v, mostly it's the audio output that looses performance first... I've used AA5 tubes in 12v car radios, all I ever tried worked but performance on RF/IF circuits was down somewhat... Norm Leal wrote: Built a lot of radios using 1 1/2 volt tubes. They are best for battery use (portable) but require two voltages.
Tom posted an interesting circuit that I've never seen. Car radios used an additional transistor stage. This one only requires 12 volts @ 1 amp. Easy to make power supply. It's in the link but there is even a hot rod version... I have two 12K5s, a few other low B+ tubed from junk car radios and AA5 that's built on plexiglass... Hasn't worked in years just needs a little TLC, ummm five sockets ready to go... Wonder how much out that PP setup would make at 25-30v??? The 12K5 is rated 30v and the others probably are as well...
| Top |
MrE12AX7
Post subject: Re: I want to build a superhet Posted: Jul Tue 24, 2012 12:50 am |
| Member |
I built a 12k5 push pull amp before and it plenty of output
| Top |
shinkuukan
Post subject: Re: I want to build a superhet Posted: Jul Tue 24, 2012 8:46 am |
Joined: Dec Sun 14, 2008 3:33 pm Posts: 295 Location: Tokyo
| Top |
MrE12AX7
Post subject: Re: I want to build a superhet Posted: Jul Tue 24, 2012 3:36 pm |
| Member |
yes I saw the site
| Top |
MrE12AX7
Post subject: Re: I want to build a superhet Posted: Jul Sat 28, 2012 3:12 pm |
| Member |
I have built a radio but don't know if it works
| Top |
Flipperhome
Post subject: Re: I want to build a superhet Posted: Jul Sun 29, 2012 4:34 am |
| Member |
Joined: Nov Sat 26, 2011 4:09 am Posts: 952 Location: Texas. USA
MrE12AX7 wrote: I have built a radio but don't know if it works Wouldn't that be like if you can tune and receive stations then it works but if you can't then it doesn't?
| Top |
MrE12AX7
Post subject: Re: I want to build a superhet Posted: Jul Sun 29, 2012 5:34 pm |
| Member |
it is not finished
| Top |
PBPP
Post subject: Re: I want to build a superhet Posted: Jul Mon 30, 2012 1:27 am |
Joined: Jun Tue 21, 2011 8:27 pm Posts: 2087 Location: Virginia
If it isn't finished then how can it work?
| Top |
35Z5
Post subject: Re: I want to build a superhet Posted: Jul Mon 30, 2012 2:09 am |
| Member |
I have a feeling English may be MrE12AX7s second language & just possibly past tense was used for present...
| Top |
MrE12AX7
Post subject: Re: I want to build a superhet Posted: Jul Mon 30, 2012 10:53 pm |
| Member |
it isn't finished I am using a 6as5 for the output tube and 6ba6 6be6 6av6 for the rest of the tube
| Top |
Users browsing this forum: No registered users and 1 guest |
