It is currently Jan Tue 22, 2019 6:48 pm
Post New Topic Post Reply  [ 1487 posts ]  Go to page Previous  1 ... 65, 66, 67, 68, 69, 70, 71 ... 75  Next
 Post subject: Re: PRINCELY PAUPER
PostPosted: Jan Thu 12, 2017 11:18 pm
john8750 wrote:
Was looking at this one.
http://www.ebay.com/itm/252690641901?_t ... EBIDX%3AIT
I think it is AM and another band. Has 6 tubes and a selenium stack. Could the face glass be replaced/repaired? It is only $42.50 shipped to my house. I also like the RCA, although looks like a crack in the plastic case on the top. But that face for the dial indicator is gorges. That would sell it in my opinion.
This is a Detrola... but there is no model number listed that I can see.
PostPosted: Jan Thu 12, 2017 11:23 pm
john8750 wrote:
you frustrate me when you don't answer the other questions too... lol
But where did you find the other radio was 6 tube, w/selenium stack?
Which radio?
Again, I don't know what you are talking about. Go here and you will find the model number. Detrola 343.
http://www.nostalgiaair.org/pagesbymode ... 004015.pdf
Im not sure that is the correct schematic yet. It shows two different schematics.
The number on the set says 343, 9259. I believe the No. 9259 is a serial No.
But that was not the link before. The other link was to the ebay picture of the Detronla radio... but no model number.
This lick is only a schematic... which is the picture on Ebay for this?
The model number can be read in the third Ebay pic (and that's where the 9259 comes from as well).
Then, armed with the model number, he looked it up on nostalgiaair.
PostPosted: Jan Fri 13, 2017 12:24 am
Yes.. thanks... he called... we got it now... lol
PostPosted: Jan Sat 14, 2017 12:20 am
Back at the caboose and back to work on the preamp. Just installing the connections to the selector switch, and going on with the construction of the tone controls.
John Smith, over and out.
PostPosted: Jan Sat 14, 2017 2:46 am
You may use up the wordl's supply of solder.
PostPosted: Jan Sat 14, 2017 5:41 am
You aint kiddin Peter. I'm getting there. A lot of stuff because the schematic is times 2, left and right channel.
So I take breaks and keep the fun in it. Looks like I installed exactly enough tie points. None are left open. About thirty of em.
I want to tell ya, it will be a big miracle if this amps works on first power up. There are a lot of connections.
But it is a great project. I want to get it in one piece before moving home on the 23rd.
PostPosted: Jan Sat 14, 2017 5:43 am
Hey, I won the bid on a RCA radio. Check it out. Now I have projects lining up.
http://www.ebay.com/itm/VTG-1946-RCA-Vi ... 7675.l2557
Whats the chance that the tubes are good?
PostPosted: Jan Sat 14, 2017 6:19 am
That one says it has a crack in the case. Did you see that?
....but other than that it looks like a good one for you to start with!
I thought you were interested in that other white RCA 45x12 ?
PostPosted: Jan Sat 14, 2017 6:27 am
Moving back home permanently? No more caboose?
btw.. when you solder the left & right channels.. do you use the iron in your left & right hand per channel?
PostPosted: Jan Sat 14, 2017 6:30 am
I did like it, but did not want to pay $65. This one cost $36. The crack is not bad and I like the dial on it. Here is the schematic. A very small power supply. Looks like it has two filter caps, a resistor and part of the output transformer.
http://www.nostalgiaair.org/pagesbymode ... 015065.pdf
PostPosted: Jan Sat 14, 2017 6:35 am
Yes, moving home and no more caboose. Although I will still involved in the club, BOD, and stuff.
Sorry Peter, I can only use my right hand for that. But, I do close the other eye and lean in that direction. That's called applying some "English" :lol:
PostPosted: Jan Sat 14, 2017 6:43 am
I get it.. sure price is right .. nice radio.
The power supply is very typical for AA5 radios.
In this case the B+ forms a pi-filter as it goes to the 1st filter cap then on to the output transformer tap and then through a hum-bucking winding and a 1200 ohm resistor and then the 2nd filter cap.
PostPosted: Jan Sat 14, 2017 7:05 am
I think the price was good for the looks, and for my first attempt.
I see about the power supply. I was fooled by the two caps sitting next to each other. Where is the hum bucking winding? Part of the OT?
I will need to find a store with a tube tester to check the tubes.
PostPosted: Jan Sat 14, 2017 7:09 am
Yes.. it is that 9 ohm winding section.
Tube checker in the drug store? ... lol ... yeah.. good luck
Tubes are your least worry. If the filaments light... most likely they will be fine.
The best test for any tube is the radio it comes from. If it works in the radio.. it doesn't matter what a tube tester indicates.
However the 35z5 rectifier tube has a 2 section filament w/a 6v tap for the dial lamp. That can burn out if you try to run the radio w/o the #51 dial lamp.
Then the tap section can blow and the whole filament series may become open. So if the dial lamp is out, tet the set is playing.. quickly replace the lamp. to save the 35z5 filament tap.
Ref:
http://www.angelfire.com/electronic/fun ... AA5-1.html
Ref:
http://www.philcorepairbench.com/tips/svctip40.htm
PostPosted: Jan Sun 15, 2017 2:53 am
Ref:
Ref:
Thanks for the info Peter. I will read that reference as we go. I remember reading that in the AA5 info you referred me to.
Right now I am finishing the preamp. Should be within tonights work.
PostPosted: Jan Sun 15, 2017 4:43 am
Shes wired.
Before
After
PostPosted: Jan Sun 15, 2017 4:49 am
Looks nice John.
I see you marked the chassis baffle with "L" & "R"
.... so I guess that's directional instructions for the mixed up electrons to follow in the dark?
PostPosted: Jan Sun 15, 2017 5:11 am
john8750 wrote:
Shes wired.
Before
After
For all the jokes about it looking like a bomb exploded I think she's neat and gorgeous.
PostPosted: Jan Sun 15, 2017 5:14 am
Looks nice John.
"Looks nice" Compared to your work, no. I am proud of it though and sure it will perform as good as the power amp.
That L/R was put there for the name of a song I wanted to remember. But I cant remember what it stands for now.
So, I have all the commons connected to the star right at the B-. Where should I connect it to the chassis? If anywhere.
PostPosted: Jan Sun 15, 2017 5:16 am
Flipperhome wrote:
john8750 wrote:
Shes wired.
Before
After
Thanks Flip. I love it.
Now, where do we connect the common to the chassis?
