It is currently Oct Sat 20, 2018 9:12 am
 Post subject: Home Made Probes
PostPosted: Jan Wed 11, 2017 2:14 am
Having a need for another probe for my signal tracer, I built this one at work today. Forgive the shameless plug for my employer. I used a pen body, made the tip from plated buss wire. Which I coated with solder in a solder pot. Used a .01 uf 1000 volt axial cap, some thin coax , very thin probe wire,and a BNC connector. Checked it out this evening, while working on a Old Drake 2B. Works will enough for me. All the parts were left overs from projects I have been working on in the Lab. I also check the insulation value of the pen body use a AC/DC Hi-Potter. It was good to 5KV, with no signs of break down. I enjoy making things like this. Now working on a Bread Board project. Hope to have if finished in a few weeks. I will post about it when done.
 Post subject: Re: Home Made Probs
PostPosted: Jan Wed 11, 2017 3:48 am
Nice work!
 Post subject: Re: Home Made Probes
PostPosted: Feb Wed 01, 2017 5:06 pm
That is the nicest execution of an old idea that I've seen.
Ted, KX4OM
PostPosted: Feb Wed 01, 2017 7:35 pm
Thanks Ted, Sometimes the small projects give the beat results.
