Author |
WoodchuckTN
Post subject: Re: Unknown homemade antique tube device Posted: Jan Tue 10, 2017 1:02 am |
Member |
Joined: Dec Sun 21, 2014 6:37 am Posts: 1459 Location: Portland, TN, USA
The more clues we have, the closer we can come to determining what it might be.
As I said earlier, it's decently put together.
_________________ Chuck K4CCW Want Hallicrafters S-76
Top |
WoodchuckTN
Post subject: Re: Unknown homemade antique tube device Posted: Jan Tue 10, 2017 1:50 am |
Member |
Here's a link to more bottom pictures that show the connections to the 1 henry choke. They are the two orange leads. Best I can tell, that choke is in parallel with the big variable cap. I may try to process the pictures and upload at some point, but I'm too tired at the moment from replacing the 7F8 socket fasteners on an SX-43. https://drive.google.com/drive/mobile/folders/0B0DqApsPCs8CaVp6S3VJNXhKeHM
Top |
infomet
Post subject: Re: Unknown homemade antique tube device Posted: Jan Tue 10, 2017 2:00 am |
Joined: Mar Sat 08, 2008 3:21 am Posts: 321 Location: hillsborough, nc
Top |
sml132
Post subject: Re: Unknown homemade antique tube device Posted: Jan Tue 10, 2017 2:32 am |
WoodchuckTN wrote: Best I can tell, that choke is in parallel with the big variable cap.
You are correct
Top |
WoodchuckTN
Post subject: Re: Unknown homemade antique tube device Posted: Jan Tue 10, 2017 3:18 am |
Member |
So... the evidence is mounting that you have yourself an audio oscillator of some sort.
Perhaps,further googling of homebrew audio oscillators will turn up a circuit. However, like a homebrew piece I posted about last year, the tubes that are in there may not be what it was designed for, although they would certainly be suitable for such a circuit. I'm just saying in your research, don't assume they're necessarily correct, but they're a starting point at least.
Top |
sml132
Post subject: Re: Unknown homemade antique tube device Posted: Jan Thu 12, 2017 12:51 am |
I have searched a bit, to no avail currently, and tested the output screws on the chassis. Two of the output screws have 120v across them and the other two have no discernible voltage across them.
Top |
WoodchuckTN
Post subject: Re: Unknown homemade antique tube device Posted: Jan Thu 12, 2017 4:12 am |
Member |
That's a pretty high voltage to have on exposed terminals like that. Please be carefulness!
About the only way forward is to trace out the circuit and draw up a schematic, which hopefully you or someone you know can do.
Top |
Mr. Detrola
Post subject: Re: Unknown homemade antique tube device Posted: Jan Thu 12, 2017 5:37 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 26283 Location: Detroit, MI USA
Just plug it in to a variac and slowly power it up, while checking the terminal strips with a scope to see what if any waveform is present there. One of them is likely an output.
It's also a very simple device and wouldn't take more than a few minutes to draw the schematic by hand using the tube basing information which is readily available.
_________________ Dennis
Top |
battradio@
Post subject: Re: Unknown homemade antique tube device Posted: Jan Sat 14, 2017 7:39 pm |
Member |
Joined: Jul Fri 18, 2008 10:02 am Posts: 2024 Location: near ST Louis Mo 62002
It appears to be a receiver for listening to VLF frequencies ,possibly ground waves .
_________________ Mark
Top |
sml132
Post subject: Re: Unknown homemade antique tube device Posted: Jan Fri 20, 2017 7:49 am |
Hopefully this weekend I'll be able to draw up a schematic. Thanks for the reply.
Top |
sml132
Post subject: Re: Unknown homemade antique tube device Posted: Jan Fri 20, 2017 11:53 pm |
Top |
sml132
Post subject: Re: Unknown homemade antique tube device Posted: Jan Sat 21, 2017 1:25 am |
Mr. Detrola wrote: Just plug it in to a variac and slowly power it up, while checking the terminal strips with a scope to see what if any waveform is present there. One of them is likely an output.
It's also a very simple device and wouldn't take more than a few minutes to draw the schematic by hand using the tube basing information which is readily available. I did what you suggested, minus the Variac. I don't have one of those at the moment. Check out my post with the link.
Top |
sml132
Post subject: Re: Unknown homemade antique tube device Posted: Jan Sat 21, 2017 1:26 am |
WoodchuckTN wrote: That's a pretty high voltage to have on exposed terminals like that. Please be carefulness!
About the only way forward is to trace out the circuit and draw up a schematic, which hopefully you or someone you know can do. I made a schematic and I don't think it's an audio oscillator. Check out my recent reply
Top |
sml132
Post subject: Re: Unknown homemade antique tube device Posted: Jan Sat 21, 2017 1:33 am |
Top |
WoodchuckTN
Post subject: Re: Unknown homemade antique tube device Posted: Jan Sat 21, 2017 1:57 am |
Member |
I saw your schematic and notes right away, but I'm afraid I'll have to ponder on it for a bit when I have more time and earlier in the day when the synapses are firing more fully.
Hopefully others will jump in and solve the puzzle as folks around here are so good at doing.
Top |
battradio@
Post subject: Re: Unknown homemade antique tube device Posted: Jan Sat 21, 2017 2:18 am |
Member |
it , is some form of a grounded grid amp , most most likely needs an ant balun , for it to work .
Top |
sml132
Post subject: Re: Unknown homemade antique tube device Posted: Jan Sat 21, 2017 3:04 am |
battradio@ wrote: it , is some form of a grounded grid amp , most most likely needs an ant ballum , for it to work Could you elaborate a bit please? Like I said I'm pretty new to this stuff.
Top |
battradio@
Post subject: Re: Unknown homemade antique tube device Posted: Jan Sat 21, 2017 4:04 am |
Member |
https://en.wikipedia.org/wiki/BalunThat is a low frequency ground grid amp or radio , and need a balun or input transfomer for it to operate, . that is why it won't pass a signal and have 140 volts to ground at the input . The tuning circuit is in the plate circuit , and has to have a resistor across the input or a balun to complete the the cathode circuit to ground . The tuning cap and the inductor across it values will tell us the frequency range it is supposed to tune .
Top |
sml132
Post subject: Re: Unknown homemade antique tube device Posted: Jan Sat 21, 2017 4:07 am |
battradio@ wrote: . that is why it won't pass a signal and have 140 volts to ground at the input . So the terminals with 120vdc across them are the input?
Top |
battradio@
Post subject: Re: Unknown homemade antique tube device Posted: Jan Sat 21, 2017 4:13 am |
Member |
Top |
Users browsing this forum: Pbpix and 2 guests |
