It is currently Feb Tue 20, 2018 2:47 pm
 Post subject: When the broadcast station has a 'problem'.
PostPosted: Nov Fri 17, 2017 10:52 am
G'day all, with apologies to Apollo 13, our main local AM broadcast station had a fairly significant outage the other morning, apparently with issues with equipment at the transmit site, which was resolved with equipment replacement after some hours.
An interesting result that may have existed previously without being overly noticed before the actual outage! The transmit audio quality is now vastly improved, and in fact my old reliable MK484 AM tuner now sounds very hi fi! I'm going to try and find out what the technical issue actually was, however in any case, things sound really good now! Regards, Felix (vk4fuq).
 Post subject: Re: When the broadcast station has a 'problem'.
PostPosted: Nov Fri 17, 2017 6:58 pm
When you post a follow up please be as technical as feasible. I will be able to elucidate for those not familiar with broadcast equipment as I have been a radio station engineer for nearly 50 years.
Dale H. Cook, Radio Contract Engineer, Roanoke/Lynchburg, VA
http://plymouthcolony.net/starcityeng/index.html
PostPosted: Nov Fri 17, 2017 11:24 pm
Hi Felix. Did the station install new processing equipment? Did Australia impose new standards on the am broadcasters there? Here in the U.S. we adopted the NRSC standard which imposes a modified 75us pre emphasis curve. This would make the high end get through narrow banded tuned circuits. Our system has a brick wall filter at 10KHZ.
PostPosted: Nov Sun 19, 2017 9:00 pm
G'day all, I've just been informed that the issue was the Optimod (processor) failure. Apparently it was faulty but still 'working' for some time beforehand. Regards, Felix (vk4fuq).
PostPosted: Nov Sun 26, 2017 1:10 am
I have heard plenty of failures and dead air from stations in the region here. Sometimes it takes awhile to come back. Probably part of the reason is their engineering is usually on-call contract or such, no money for on-duty engineers at stations anymore, I suppose. And no official requirement for that.
PostPosted: Nov Sun 26, 2017 2:22 am
For $8000.00 you would think they would have a spare processor on hand.
https://www.orban.com/optimodam-9400-3
PostPosted: Dec Sun 03, 2017 6:38 pm
We could have a separate thread on what goes wrong at AM broadcast stations (FM for that matter too.
Some examples. Summer once in another life, I am filling in for a buddy who was contract engineer on vacation. Local 1 KW AM mom and pop says transmitter on the air but no program material. I go there on a Sunday morning at 0700. Telco leased line to studio dead. I tell the manager we have to call AT&T. Oh, but I know why it is dead, he protests. Want to share? Well, he hadn't paid the bill in 6 months and they finally disconnected it.
Same station, 2 months later. Super hot summer day. Transmitter off the air. I find the breakers tripped and see the top panel of the transmitter was not on and lying in a corner. Interlocks defeated. Seems the helpful DJ had found the PA compartment fan had failed and had taken a table fan he got at Walmart and propped it over the PA pointing down inside. Some hours later the fan had vibrated enough to plunge off the rack cabinet edge into the now open PA compartment. With obvious results. :x
Same summer, the VSWR trip-out on the transmitter had activated. Upon arrival found alarms lit for VSWR. lightning and overtemp. Reason? A rattlesnake had gotten into the antenna tuning box and wrapped himself around the large coil. He was half cooked but the rest of him was still lethal. His remains are nailed to the wall on the back of the transmitter building wood siding as a warning to others.
WB6NVH
http://www.wb6nvh.com
PostPosted: Dec Sun 03, 2017 7:03 pm
Don't get me started - I've been battling such problems for nearly 50 years.
PostPosted: Jan Sat 06, 2018 4:05 am
Dead air on AM's in this market is part of the hourly playlist! One, in particular, airs an entire hour of it daily. And it's owned by one of the (recently declared bankrupt but still somehow running) BIG companies. It's the best program on the station, IMO.
I've been out of broadcasting since 1998. I had 25+ years in. Things were getting pretty bad from TCA1996 already at that point. I sure miss local owners!
It was like that when I got here!
PostPosted: Jan Sun 07, 2018 4:16 pm
When I experience dead air, it's usually fixed by a trip out back to reboot computer... Did have one CPU fan failure causing choppy audio from overheated processor...
Only xmitt failures have been a intermittent power xfomer and a 6AU6 audio amp shorted H-K... Of course the 6AU6 created anything but dead air...
